Question about Euro-Pro Shark GI490 Iron
Dirty water spraying from iron - Euro-Pro Shark GI490 Iron
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that will help you see why you are getting dirty water from your steam iron...
Cleaning a Steam Iron White Scale and Brown Water
http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown
heatman101
Posted on Jul 14, 2010
My stream iron generator tefal and problem some parts outstanding on base of iron , and stream can not get out , how to remove PARTS.
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Oct 02, 2013 | Tefal Irons
WATER HOSE PERISH
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 01, 2013 | Irons
How to open a steam iron severin
follow this principle.God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jul 20, 2013 | Severin Steam Iron, 2500 Watt, White...
Steam iron turns itself from hot temperature to cool
1) test the electronic control for defective and follow the next steps. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Jun 11, 2013 | Irons
Pump wont run
Clean an iron:
  1. Unplug the iron.
  4. God bless you
Apr 04, 2013 | Rowenta DG-980 Iron
Water is leaking out of the bottom of my philli[s GC 9240
see the next steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 14, 2012 | Irons
How to clean the brown dirty water ,what can I use
see this step and fix it. God bless you
Clean an iron:
Oct 01, 2012 | Tefal Pro Express GV 8120 Iron
When I iron my white sheets dirty water comes out and my sheets are dirty
follow the steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Dirty water in my iron
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust. It is a pretty common problem that can be minimized by using distilled water. You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar: 1) with a cold iron, fill the reservoir with straight vinegar 2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity. 3) Refill iron reservoir with clean water and repeat as of step 2. 4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
Feb 24, 2010 | Bosch TDA8340 Iron
Water spray not working
I got a thin needle and gently made a hole through the centre of the nozzle - where the water would usually come out. That cleaned the scum build up out of it and it's working fine again. My nozzle does seem to look like its going into the iron but perhaps it's to get the correct angle of spray onto the clothes.
Feb 13, 2010 | Sunbeam Irons
Euro-Pro Shark GI490 Iron Logo
195 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
