Question about Kodak EASYSHARE Z1485 IS Digital Camera
Pictures bright on camera LCD and dark on computer
Pictures look bright and perfectly exposed on camera LCD and dark on computer monitor after downloading to computer. I have to brighten them several stops on photoshop! Why is this happening and what can be done? Is there an LCD exposure adjustment? How do you adjust the camera so it allows more light into each shot. Is there a quick push feature? My computer monitor is a Hansol 900P, I am running Windows XP, SP3. I also have Photoshop 7.
  • rick462 Jun 07, 2010
    There is no way to adjust exposure compensation on this camera...
    Brigadier General:
  • 11,967 Answers
You can set the camera's "exposure compensation" to a higher number.
Posted on Jun 07, 2010
  • Ty Price Jun 07, 2010
    This is on page 38 of your manual...
    Using exposure compensation to adjust brightness
    In P, M, and Panorama modes, you can adjust exposure compensation before you take
    a picture to make your pictures darker or lighter. Only the first picture in Panorama
    mode can be adjusted—that adjustment is applied to the remaining pictures.
    1 Press to access the exposure compensation setting.
    2 Press to decrease or to increase exposure compensation.
    An exposure compensation level is shown on the LCD and the image gets darker or lighter.
    3 Take the picture when you are satisfied with the exposure compensation level.
    Using exposure compensation with exposure bracketing
    In P and M modes, you can use exposure compensation (see page38) in conjunction
    with exposure bracketing to get the best exposure.
    If the exposure
    compensation is set to: And if the exposure bracketing
    interval is set to 0.3 steps: Then the exposures
    taken are:
    0.0
    +1.0
    –1.0
    (Set the Exposure Bracketing Interval
    in the Capture + menu.)
    –0.3, 0.0, +0.3
    +0.7, +1.0, +1.3
    –1.3, –1.0, –0.7
SONY DIGTIAL
You never should use the picture you see on the monitor of the camera. Not one camera has a calibrated screen. And the brightness is changed very easy in the setup menu.
To test if your camera shoots good pictures, select AUTO on the mode dial. Shoot some pictures and look on the PC or just print them.
Your camera has so many settings, that over rule the brightness when you switch to it, like + and - 2 EV setting. But when you chose for A, P, S, or M, the pictures can be to dark or to bright, if you dial in the wrong settings. So don't evaluate the pictures on the monitor. Only use the histogram on your camera to see if you have a correct, to dark or to light picture.
Jan 06, 2014 | Panasonic Lumix DMC-TZ3 Digital Camera
Over-exposed & Lines Picture problems! Please help!
Kate,
It's six years old - at $90, that represents a mere $15 per annum. Just replace it.
Jun 11, 2017 | Sony Cyber-Shot DSC-H70 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera: The camera LCD display is extremely dark with shadows/outlines of reddish pink hues and the same image is shown when a picture is taken. I have tried transferring...
Did u check the settings of the camcorder? see the setting there you got contrast settings if its low then you'll get dark images or its exposer meter's problem U check the exposer meter's reading and see aparture also.
Mar 09, 2011 | Cameras
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Dell display is dark
Leave the monitor hooked up to the computer with you booted up into windows.Go into the menu on the monitor itself. There should be a button on the monitor itself that will allow you to go into its own menu. From there try to find the brightness and contrast controls and turn them up. If after you turn them up the display stays dark then your monitor is bad and it will need to be replaced.
Dec 30, 2008 | Dell E153FP 15" LCD Monitor
Dark LCD screen
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jan 11, 2008 | Pentax Optio W30 Digital Camera
Dark
It could be a few things, it may be the monitor itself, which naturally has dark picture.
Or by factory default the monitor has low brightness.
Try going into the menu and putting the brightess up.
Most monitors have low brightness by default.
have a happy new year.
Dec 29, 2007 | CTX S762A 17" LCD Monitor
Very bright pictures...
Make sure the Exposure Compensation is set to 0. You can find it in the camera menu.
Dec 28, 2007 | Olympus Stylus 710 Digital Camera
Transfer from XTI camera to PC
Seems to be a common problem with the XTi. Some say it's designed to underexpose to avoid washing out the bright parts of scene. Personally I found it a pita. I had to PhotoShop each shot.So I sent it back to the repair facility. They re-calibrated it. Now it works fine.
Sep 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
DSC-S75 - LCD shows better than actual pictures
could be a monitor miscalibration. Sometimes, pictures will be different than what it appears LCD monitor brightness cud be high and PC monitor brightness might be low... Did u try printing some of the dark pictures? if printed photos are different, then its defintely a calibration issue.
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Kodak EASYSHARE Z1485 IS Digital Camera Logo
101 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
