What size filter do you need with a Carrier WeatherMaker 800TS with comfort technology and how do you install it.
  • 1,284 Answers
Hi, you have to measure the furnace width and depth and that will tell you the size of filter you need. Most likely a 16 x 25 or maybe 20 x 25.
The filter should be placed any where around the return air duct, you can also consult the installation manual to get more info....
Take care
Posted on Jun 06, 2010
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
2003 carrier weathermaker 38tkb unit 40,000 btus 10.5 seer 3.5 ton - what should start amperage be?? is 132 too high tks
as you are running 2.5 or 3 mm wire for the unit , at 132 amps the wire would melt
check the setting of the amp meter as it is more like 13.2 amps which would be about right
use an example , check the size of the wires from a battery in a car and that size wire carries 400 amps minimum when starting a car, then check the wire size to the unit
all compressors start with a high current draw ( 25 amps ) but it drops of to running current after a 1/2 second or so
May 24, 2016 | Carrier Heating & Cooling
Carrier weathermaker 8000
The filter should slide out of a built in rack from the side of the furnace by the return inlet. It should have the size on it or you'll have to measure it. It may also be inside the bottom door. Pull the door up and out, the filter will be on one side or the other. Unless you have a special Hepa or electronic filtering system.
Dec 12, 2013 | Heating & Cooling
Carrier weathermaker 9200 furnace air filter placement
air filter for your model can be found on amazon, click here and take a look: 20x25x5 Electrostatic Washable Furnace and Ac Filter 19 3 4 24 3 8 4 3 8. I hope this was helpful. Cheers
Feb 17, 2013 | Heating & Cooling
I need to change the filter in my Carrier Weathermaker 8000. WHERE IS THE DOOR?
There is a filter on the bottom of the unit. You will either have to remove the bottom panel in the front. Or thereis a thin acess panel down in the front of the unit.
Oct 24, 2008 | Heating & Cooling
Carrier 8000 weathermaker filter
The filter should be located in the front there should be some kind of tab to pull out the filter.
Oct 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
HEY< so this is an upflow system, there can be only 2 spots, 1 below the fan in a little rack, or follow the return air vent system ,(thats the sucking side,) and theres a large grill that sucks air in thats the filter grill, If you unlatch the door, and open it you can measure the inside lips that holds the filter, thus the filter grill! But it this filter is hard to fit, then theres only a plain grill and you need to add a filter inside the air handling unit below the fan cage,, and add a"blue MO-hair type filter , size to-cut and add below the fan!Thank-you-very-much!
Aug 30, 2008 | Heating & Cooling
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
