Hi,you can use this steps to troubleshoot the refrigerator.
There are many things that can go wrong with a Kenmore refrigerator ice
maker. Your ice maker may be leaking. It may not make any ice at all,
or the ice that comes out smells or has an odd appearance. The problem
may have an easy solution, or it may require a technician's expertise.
The troubleshooting tips in this article will minimally make you aware
of what is likely the source of the problem. You may be able to fix the
problem yourself and save a bundle.
When it Won't Make Ice:
Things You'll Need:
Get a thermometer and see how cold it is in there. If your freezer is
fewer than 17 degrees F, it won't make ice. The freezer temperature
setting may be too high or the thermometer is broken and not calibrated
correctly. If adjusting the temperature fails to work, call a Kenmore
technician.
Determine if your water fill spout in the freezer is plugged with ice.
If so, no new ice can be made. Try clearing it out or melting the ice
by running a hair dryer on it for a few minutes.
Turn your refrigerator around to look at the back side to see if water
is getting to the water inlet valve behind the fridge. If the water is
not properly connected, there's no water to make ice.
Use an ohm meter to test for coil continuity. If the ohm meter shows
there is no continuity, then you will need to replace the water inlet
valve.
When the Ice Maker Leaks:
Refer to your user manual to determine where your fill volume adjustment
dial, is and turn it down. One-half to one full turn usually is
approximately equal to 20 to 40 cc, and the correct fill is usually 130
to 150 cc ( 4.5 to 5.0 oz ).
See if there are icicles hanging from the fill spout and/or on the ice
maker's sides. If there are, this means your water inlet valve is
leaking and will need replacing. Refer to your user manual for a part
number, or call a technician.
Check to see if the ejector seal is cracked. If it is, replace it. Refer
to your user manual for a part number, or call a technician.
Tips & Warnings
Take care.
