Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
The seat saftey switch is not functioning correctly. i have replaced the switch and it still is not working. the problem was someone cut the wires and bypassed the switch. when i hooked it up with the new switch and connected it at first and took off the brake the endine stopped. i switched the wires around and then when i tried to engage the clutch the engine stopped. i can get it to run but with only one wire used and the clutch and bades remain running even when i get off the seat. not sure how to fix this.
    Brigadier General:
  • 3,911 Answers
Those safety switches connect to a central relay up by the engine. That relay has been known to fail, especially in the craftsman mowers. Some folks have taken the relay out of the wiring harness, heaven forbid, and it cures many of these craftsman mower won't run when I take my foot off the brake problems. Of course if your dog and kids like to play around your mower when you are getting another beer, stand by to be sued for all the dead pets and missing toes for leaving it running unattended.
Posted on Jun 07, 2010
Lt 1045.....clutch to mower began to cut out occasionally, now it will not engage at all. Also, engine now stops when I take my foot off the brake pedal. Are problems related?
Yes the problems are likely related. The saftey switch under the operators seat is most likely failing. To start the tractor either the brake must be set or the driver in sitting in the seat. To operate the PTO (power take off ) the driver must be in the seat!
Suggest test with multimeter seat saftey switch to confirm the problem.
65543-ckugwuakuglxvdrsjlbftzu3-4-2.jpg Hope this helps?
Jun 20, 2017 | Garden
The seat belt chime on my 2008 pt cruiser stopped working. The seat belt indicator light still functions correctly. How do I fix this?
you need to replace the switch in the seat belt clip ,I will bet the small wire has snaped,dont repair replace it,cheep and easy to do .
Jun 15, 2017 | Seat Cars & Trucks
1897 Yamaha Fzx 750 runs but stalls when put in first gear. Was working yesterday...
Saftey circuit issue! check clutch switch, side stand switch and wiring these are connect to the neutral light switch and the 3 are part of the saftey circuit,
circuit is designed to cut the bike out if the stand is down and you kick it in gear also to stop the bike turning over & jumping forward when you hit the starter and its in gear and the clutch isnt pulled in.
weak stand spring my not be pulling stand onto the stand switch correctly there fore no making the curcuit, switches just make and break the curcuit.
Aug 30, 2011 | 1989 Yamaha FZX 750
Mower Cranks. Blade engages. When you take foot off clutch, mower cuts off
you may have a saftey switch problem on the seat
look under the seat and see if any wires are off or the switch is loose
Feb 27, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
CUB CADET LT1050 WHEN I TURN KEY DONT MAKE A SOUND
LOVE THOSE SAFTEY SWITCHES/ YES IT SOUND LIKE ONE OF THE SAFTEYS IS NOT WORKING CHECK THEM ALL FROM THE SEAT , MOWER SWITCH, BREAK SWITCH, NUTURAL SWITCH,
THE BEST WAY IS TO TURN THE KEY AND HOLD WHILE YOU CHECK ALL THES SWITCHES
Aug 25, 2009 | Garden
My rzt 50 series cub cadet zero turn mower slows down with blades engaged?? one of the wires is missing on saftey switch under seat . where does the wires connect to??
The saftey wires wont cause it to slow down.Thats more of a fuel problem.Check the carb remove and clean the float chamber.Also check advance and ****** springs are still in good working order on carb.
Jul 06, 2009 | Garden
Mower starts but when you take your foot off the clutch it stops
sound like the seat saftey switch under seat you can either unplug it and see if that works or jumper the wires with a piece of wire if either works replace switch
Mar 24, 2009 | Craftsman Laser Level - Sears 180 Degree...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
153 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
