Question about Oreck BB2000 XL Little Hero Canister Vacuum
Took canister apart to replace power cord. some grid fell out before i could see where it was. need to know where it goes
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Euro Prox Model UV209-11 upright vacuum--
prise it apart I'm pretty sure it has clips much like a computer case.
Dec 13, 2012 | Euro-Pro UV209 Upright Vacuum
Where are the screws/tabs that hold the kenmore 25513 case together? The vacuum makes a "clicking" noise like a relay is kicking in but the motor will not turn on. I suspect siezed bearings.
The screws that hold the cover are under the spring loaded "bar" for retractng the cord. To get at the screws one has to pry the bar loose! The problem with the motor is that something fell apart within it (small bolts fell out).
I do not see any non-destructive way of taking the motor apart.
Dec 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Power cord broken inside reel
the reel doesn't come apart, its a replaceable item. the only place that you can get another one is through sears.
Jul 19, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Power cord reel problem with a kenmore canister vacuum whisperti
Pull the cord all the way out and see if it's contaminated with anything sticky. Also check the guide rollers that the cord rides in and see if they are rolling smoothly and without resistance - they may also need cleaning. If so, clean it off and try again.
If not, it may be the spring reel itself in which case you may need to replace it.
Apr 30, 2009 | Kenmore Progressive 20912 Bagged Canister...
Need to replace power cord
Here are the Sears links to purchase both the part and the manual.
http://www.searspartsdirect.com/partsdirect/searchByPartDescAction!searchByPartDescription.pd?brandId=0582&productCategoryId=0645000&modelNumber=11633922300&backToLink=Return+to+Sub+Components+list&partDescriptio
Dec 31, 2008 | Kenmore 22612 Bagged Canister Vacuum
My filter queen fell apart!!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=20821&thid=780805
Posted by julieartlit on Jul 14, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Not knowing what actually fell apart is to contact your local vacuum cleaner dealer in your area or to call the Filter Queen factory cust serv or tech serv @ the phone # listed below, you can also request a new owner’s manual so that you might see what actual fell apart and you might be able to fix it yourself. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.filterqueen.com/
Customer Service 1-800-344-1840
custserv@filterqueen.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Filter Queen Majestic Canister Vacuum
My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Oreck BB2000 XL Little Hero Canister Vacuum Logo
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
