Question about HP OfficeJet 7310 All-In-One InkJet Printer
Officejet 7310 misses lines while printing, copying, etc
Someone has just replaced the cartridges in our office printer and now it misses a half inch strip of the page in rows about 2 inch's apart all the way down a page whilst printing black and white. Have run its self test features and alignment, and also reset the machine. The cartridges are advertised to work on this machine and are from the Print-Rite Pro-Eco Series range. Was wondering if anyone had any ideas. Thanks
  • Anonymous Jun 10, 2008
    I have experienced the same problem. I thought I was running out of black ink, so went off and purchased the HP (very expensive) black and color cartridges, and I had my IT man clean the heads with Q tips, etc. and still the black (not the colour) when I print from my Outlook e.mail has faded unreadable print every other line all the way down the page. This is getting to ge a very expensive problem.
    Problem Solver:
  • 7 Answers
Turn off the unit.
Disconnect the Power Cable.
Open the rear access door.
Clean the rubber rollers with soft dampened clean clothes.
Let it dry for sometime.
Turn on the unit and see if it works.
If it doesn't work, your printer might have to be service.
Posted on May 30, 2008
If I print a colour copy on my HP officejet 7313, it prints out a pink colour only but prints fine on black copies. what could be the problem...?
may be the cartridge are dry or out of ink just Remove the colour cartridges and clean the nozzle with tissue paper and install it again.if the problem is solved .then ok otherwise replace the colour catridge.
Have a nice day and do not forget to rate please...!
Feb 11, 2010 | HP Hewlett Packard Officejet 7310 InkJet...
Printer alignment --- documents are printing out missing half of every line. How do I repair?
Run the print align program from the HP led panel on the front of the printer. You can usually find this by scrolling through the setup screens.
One will say something like ALIGNMENT.
The printer will also run this exact same program each time a new HP ink cartridge is placed in the machine. Once the lines dashes and color lines are printed out. Their should be an image of a bird at the bottom.
One will look out of focus the other should be near perfect.
If this does not align the print heads the machine may need servicing.
You could try a new black ink cartridge to see if the old one is damaged or clogged.
Oct 02, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp 7310 printing with color horizontal streaks across. parts of the artwork are fine, then strirated lines down whole page. changed cartridge color and b/w and says it's installed fine. test page is...
usually when there is a defect on printing out while you have changed the cartridges , you will need to consider changing the printheads of that printer.
Aug 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Vertical lines (no printing) on copy
Make sure you have visited the HP web site for the OfficeJet 7310 (it's not the 10xi model, is it?)
Check out the page on troubleshooting copying problems.
See if your vertical lines issue is addressed on this page.
Nov 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
7310 Cartidge Change Issue
You can download the drivers and utility software for the Officejet 7310 from HP's site here or you can run a cleaning cycle from the front panel - select setup and cycle through the choices.
It sounds like you have a defective cartridge, most common with remanufactured cartridges. If it is an HP original you can check the two year warranty as shown here. If the HP oriinal cartrdige is defective and still in its warranty period you can return it to your dealer or contact HP for a replacement. If the cartrdige is a store brand or some other remanufactured cartridge contact your delaer for a replacement.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 16, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hp 7310
If the color cartridge doesn't print the color bars on the alignment page (either, redish pink, yellow or blue) then the alignment process will not finish. Same for the black. If the black cartridge is printing ok, then replace the color cartridge and try this again...
Jan 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Partial line print
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Dec 19, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Printer portion
try the cleaning utilities on the computer software to see if it wil resolve the problem
Jul 09, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
111 people viewed this question
Ben Johnson
