Question about Photography
Just bought my Holga 135. Whenever I load 35mm film into it, I can never get the crank to connect well with the film spool its self. I placed the film in the correct sprockets but when i try to advance, I can't get the crank to advance a long with and I end up spooling out all this film that can't be advanced right.
    Brigadier General:
  • 3,006 Answers
Return the camera for an exchange or refund.
All Holgas are very badly made (which is why they produce the unpredictable image results that they're currently fashionable for) and it's not uncommon for them to be faulty from new. Also, don't expect the camera to last for more than about 12 rolls of film before it breaks: Holga specifically state that as an expected model lifespan on many of their model instructions and on some models they limit is even lower.
Posted on Jun 07, 2010
Why is my canon ae-1 only developing blank film
First thing I would do is sacrifice a roll of film. Load the film as you have been. Then with the back open and tension on the film (do not touch the film over the shutter, advance the film. It may be that you are putting the film on the takeup spool incorrectly. Watch how the film advances on the spool. If it is on the spool incorrectly it will disconnect then not advance. If that does not work it may be a errant takeup spool.
Jul 06, 2012 | Canon EOS-AE-1 35mm SLR Camera
Do you keep advancing the film til you get to one. I have but it still shows S. Should i start all over
When you advance the film, does the rewind crank turn counter-clockwise? If not, then you haven't loaded the film correctly onto the take-up spool and must start again.
Aug 17, 2011 | Minolta X-370S 35mm SLR Camera
How many winding clicks should i use for a holga using 35mm ?ive heard 36-24 ?which is one is correct?
Same as you use for 120mm, since the size of the image projected by the camera doesn't change by using thinner film. If you wind it less, your frames will overlap quite a bit.
Feb 27, 2011 | Holga 120CFN Film Camera
What is the proper way to load the film?
The film canister itself will have a spindle in the middle of it, with it sticking out on one side. Place the canister on the right side, with the spindle pointing upwards. There will be either a spool on the left with a series of pegs on it, or a red marking on the left side for you to place the edge of the film on. (If there are pegs, make sure the sprocket holes on the film fit over them).
Feb 18, 2011 | Canon EOS Rebel 2000 35mm SLR Camera
How can you rewind the film
Lift up the rewind crank. Press the film rewind button on the bottom of the camera and turn the crank clockwise. Rewind until the tension on the crank lessens, indicating that the film leader has been released from the take-up spool. Pull up on the film rewind crank and the back will open.
Dec 03, 2010 | Pentax ME Super 35mm SLR Camera
How do i load the film
Open the door.Drop film roll in the camera and pull film up to the mark to winding take up spool,close the door and it will get automatically pulled on the take up spool.The number 1 will appear on screen.if 0 is flashing repeat the procedure to retry the loading..
Apr 01, 2010 | Minolta Maxxum 400si 35mm SLR Camera
I have no idea how to put my film in the "Pentax mz-m" camera? Someone help me. I'm new to this as I am just doing photography at school!
Pull up on the rewind knob ( left side ) to open the film door. put film cassette in chamber then lower rewind knob and pull enough film leader to the take up spool. attach film to spool. close the film door then advance the film to #1 on the counter.
Jun 06, 2009 | Pentax MZ-M 35mm SLR Camera
Loading/ Unloading the Film
anniehongx,
open the film door and charge the shutter. are the drive and take up sprockets turning? if they are then the film was not loaded properly. be sure to push enough film leader into the take up spool bars.
if the spools are not turning then a gear or spring ( advance lever return lock ) is broken.
there are no new parts for the ME Super however some camera repair shops have good used parts that can be used. get an estimate first.
Mar 02, 2009 | Pentax ME Super 35mm SLR Camera
When i re-load film the shot counter reads " error"
Film didn't catch spool.
Try to put film on the spool, catch tooth on the spool.
Feb 05, 2009 | Nikon F80 35mm SLR Camera
Film problem for my holga
Black film as in underexpose, after you have them printed?
If you open a roll of 120 film:
Remove the little tape holding to the film.
Place film onto Film Spool Studs.
Pull film out from film leader and thread to Take Spool.
Turn until Arrow Line on film aligns with Start Mark of Film Holder.
Close film cover or back.
Advance camera to Zero (0). Now you are ready to shoot.
Just rememer what film speed your are using.
Hope they are helpful.
Truly,
atdlee@netzero.com
Dec 31, 2008 | Holga Flash, 120 Medium Format Camera...
Photography Logo
157 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
