Question about Alps MD 2010 Thermal Printer
Error message with grinding noise as driver cycles
This is actually on a ALPS MD4000, but these two models are very similar. Printer will not work. Starts cyclce then jams with grinding sound and locks up and error message flashes..
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 295 Answers
Make sure the little spring loaded side fingers that grab and hold the cart onto the printhead are not broken. With the unit off, slowly move the carriage all the way left then right to check for a good belt and free movement. Take the carts out and tilt the printer back and forth to see if something has broken off inside, check to make sure nothing has fallen into the paper rollers from behind.
Posted on Oct 08, 2010
Alps md driver error
For the ALPS printers, make sure you are using Windows XP SP2 or older. There are no Win 7 drivers and there can be problems with a Win XP SP3. Join the Yahoo ALPS group. In the files section they have a full description of the problem along with a work around. It usually is a conflict with the bi-directional communication and the LPT port. The LPT port needs to be motherboard based - not an add-on card.
I hope this works.
Nov 14, 2012 | Alps MD 5000 Thermal Printer
Maytag dryer, model: MD4000, elect. just started a rubbing metal noise when dryer starts, appears the fiber material between drums may not be position correctly. What else could be wrong, how do I get a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 01, 2010 | Maytag Neptune MDE4000 Electric Dryer
We have Alps MD 1000 which makes a grinding noise when we power it up, and then the error light comes on. Is this normal, or is what could be the problem? Where would we need to send it for repairs?...
All ALPS printers make noise when they are turned on. The error light is not normal. Do you have cartridges in the printer? there are two kinds: ones with gray plastic cassettes and ones with dark blue plastic cassettes. For the 1000, you want the gray ones. Are the cartridges installed correctly? Side B should be facing up.
Feb 06, 2010 | Alps MD 1000 Thermal Printer
Error message-"printer had any motor mis-step error"
After 8 yrs..........Get a life and new printer! Inkypete
Apr 21, 2009 | Alps MD 5000 Thermal Printer
Cartridge error
I have had similar problems with my "Older" R-series R60 and the jam was usually accompanied by a "grinding" sound from the printer mechanism. I found to be the problem was the cartridge drive belt/home positioning have been misaligned by usually inadvertive moving of the cartridge either when changing cartridges or whatever may prevoke movement. My resolution by accident, was repositioning the cartridge a little bit in either direction. And power cycling the printer until I found the position "Sweet spot" when no grinding is heard as the printer finds its home position. Maybe this will work for your unit as well if you encounter it again. It beats dismantling and still having the problem, right?
Mar 05, 2009 | HP Officejet 5610 All-In-One InkJet...
How to remove cover off Alps md 1000 printer -
Remove the 4 screws holding the main feed tray. Then GENTLY pry the tabs on both edges of the printer. They are really tight! The fit is great but once you break the "seal" so to say the whole cover just pops off.
Feb 09, 2009 | Alps MD 1000 Thermal Printer
Cradle made grinding noise and now machine wno't turn on
My Alps printer makes a grinding noise and won't pull the paper through much less print. What do I do - I print diplomas with this printer.
Apr 30, 2008 | Office Equipment & Supplies
ALPS MD1000 Won't print
Please ignore courtdate & creamgetmonE. Here's why:
creamgetmonE - If you're using the XP driver, you are using something so crippled, it should have been aborted. USE THE ALPS DRIVER!!!!!!!!
courtdate, oiling the carriage rail will not change a thing, apart from gunking up the printer, and ENSURING it will fail sometime in the future.
TO FIX YOUR PROBLEM:
There is a sensor under the anti-curl veil. Clean it.
Jan 18, 2008 | Alps MD 1000 Thermal Printer
ALPS Printer MD1000 Driver
Several things about these printers.......
1. Do NOT use the MS XP driver for these - it has limited functionality. Download the Alps driver, which you can find in the files section at the Alps YahooGroup (http://tech.groups.yahoo.com/group/Alps/files/)
2. The printer requires bi-directional comms in order to feed back the printer status to the computer. While this is not an absolute requirement, it means that without bi-dir comms, the error light will flash, and you won't know what the problem is.
3. The driver is hardcoded to only communicate bi-directionaly with Alps virtual LPT ports - run this with a non-Alps cable (And all of the cables on FleaBay are non-Alps), and you will not be able to monitor the printer status.
Now, how to install.....
1. Plug in the USB cable to the computer (But not the printer), and let it install. Reboot if required (Unlikely)
2. Install the Alps driver you downloaded fron the Alps YahooGroup. Reboot if required. If you now look at Printers in Control Panel, you will see a nice Alps printer there, waiting to be used. Make a note of what it named.
3. Plug in the printer and turn it on. XP will now tell you it has found new hardware, and install the MS driver. Reboot if required
4. Go back to Printers in Control Panel. You will now see you have TWO Alps printers! The MS driver will be called something like "Alps MD-1000 (MS)". Rename (DON'T delete!) this driver to something like "Alps MD-1000 (DO NOT USE)". If you delete it, it will come back to haunt you every time you switch on the printer, and screw up your settings.
5. Open the properties page of the driver you made a note of in step 2 (Control Panel -> Printers and Faxes -> right click on printer, and select "Properties"), and click on the "Ports" tab.
6. Check the checkbox next to the port created for your USB-// cable, and uncheck the other box that will be checked.
7. Uncheck "Enable bidirectional support"
8. Click on the "Advanced" tab
9. Select the "Print directly to the printer" radio button
10. Click on the "Print Processor" button
11. Select ALMD224S as the Print processor and select RAW(FF AUTO) as the Default data type
12. Click Apply.
Sep 23, 2007 | Alps MD 1000 Thermal Printer
Alps MD 2010 Thermal Printer Logo
110 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
