Question about Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater ()
ROL Fault code
I have a RUUD Digital Gas Heater Model 206 for my pool.
I'm geting a fault code( ROL-Heat roll-out safety switch open).
How is the problem repaired.
Heater has been working fine since end of May.
John
    Top Expert:
  • Rheem Master
  • 6,498 Answers
Replace fusible link and check gas pressure and for burners clogged
Posted on Oct 11, 2017
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
macdirk
  • 116 Answers
SOURCE: I have a Rheem raypack pool and spa heater. I have
Error Code ROL is "HEAT ROLL-OUT SAFETY SWITCH OPEN". The heater is equipped with a cutoff device to prevent flame roll-out in the event the heat exchanger becomes blocked. This is either a "manual reset", or "Single-use" type fusible link/thermal fuse, that must be replaced or reset after any over temperature conditions have been fixed. Excessive restriction in the heat exchanger flue passage may cause the switch to disable the heater. I don't know your exact model so I'm just generalizing. If you reset or replace the switch, and it trips/burns out again, then you need to address what is causing it. make sure the heater is cleaned out well and no debris is blocking the flue. I fthis doesn't help you can always try calling Raypak Service department at (805) 278-5300.
Posted on Sep 20, 2010
adamh294
  • 310 Answers
SOURCE: Rheem 266K to 399K BTU Swimming Pool Natural Gas
ROL code means Rollout.
This heater used a one time use switch in the cabinet on the left hand side.
The switch will look like a ceramic oval disk about 1.5" in diameter. It will have two wires coming from it.
This switch is one time use because it mean your heater is getting a bad burn. This could be happening due to:
1. High wind situation (could be random)
2. Incorrect gas supply
3. Incorrect venting (if indoor)
4. Obstruction on top of the burner tray.
There was a recall on the refractory kit with some of these models, causing the fire walls to crack off and fall on top of the burner tray. Thus causing the flames to rise too high inside the cabinet and therefor trip the rollout switch. The timeline for the recall matches your heaters date.
E-mail me if you need more help.
ahudson43@yahoo.com
Posted on Dec 29, 2010
How to repair a Raypack pool heater that displays a ROL fault code?
simply replacing the roll out fuse wont solve your problem. those safeties open from an over temp situation or negative pressure down draft. clean out any dirt and debri from venting, inspect the underside of heat exchanger for build up or soot. ensure you have proper combustion/ventilation air openings if heater is in a shed. if heater is outdoors, Raypack is notorious for getting downdrafts back down the draft hood causing burner flames to come outside the burner box
May 20, 2012 | Raypak Rp2100 Pr406aen 406k Natural Gas...
I am getting a ROL code on my raypak 406 gas pool heater. Does anyone know what this means?
roll out senor bad replace but check gas pressure if too low it will overheat once gas is ok then replace fusible link and clean outside of het exchange
May 11, 2012 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
I have a Rheem raypack pool and spa heater. I have an error message in the display: "ROL". Can you please describe the issue and possible solutions. Thanks, Stan.
Sep 20, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
ROL services code
Press the "mode" button until "off" is displayed. Remove the screws on the control panel and tilt the panel out exposing the back of it. On the back of the board is a small square component with a button in the middle of it. Press and hold this button until SETdef is displayed on the lcd screen (about 5-7 seconds). Now push the MODE button on the front until RESfl is displayed. Now, at the same time, press the UP and DOWN buttons until two dashes -- appear on the screen (about 5-7 seconds). Now the fault history has been cleared.
ROL is an error for the Roll Out Safety Switch. This is usually caused by flames coming out from the burners to the front of the unit. NOT GOOD! Make sure you have remedied the problem and replaced the switch. Never bypass a safety switch. I am sure you knew this last section, just wanted to put in a reminder.
Jul 27, 2010 | Raypak 130,000 BTU Propane Gas Pool...
I have raypak pool heater with services code ROL how I troublesho
roll out fuse is open. for starters you have to replace that safety. then find out what caused the over temp situation. clogged venting or heat exchanger, negative down drafts, inadequate combustion/ventilation air, improper air/gas mixtures
Jul 25, 2010 | Raypak 130,000 BTU Propane Gas Pool...
ROl Code is on, and heater won't fire
his indicates the flame roll out safety switch is bad. This part is usually mounted right above the burner tray. It is a white ceramic piece with two wiring terminals and an external part that looks like a resistor. This part detects flame/heat coming out from the burner tray. When replacing it, be sure to check for blockage at the burner tray, heat exchanger and the flue if vented with duct work. This is a critical safety device so do not bypass it.
Jun 19, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak heater. fault cde says (ROL)
John
May 31, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater () Logo
175 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
