Question about Electronics - Others
Shur-dri motor will not run on inverter
What is the start up power consumption or peak load of this motor I am trying to use it on a 2000w inverter and the inverter cannot handle the load, what size inverter wattage) will run this load? It is a shur-dri 115 v 9.8 amp motor 1 hp
Thanks,
Donald
  • 59 Answers
If your application is really One Horsepower. 745.7 watts then the inverter should be sufficient. However I can not be sure without more details
Posted on Jun 06, 2010
What do I check? i have a honda eu2000i that starts and runs but no generator power
The internal monitor is sensing a load does a load make it change tone? Check the 12 v output and see if it is loaded.
Kevin H
Sep 08, 2014 | Honda Eu2000i 2000w Generator
Burning smell
What is the wattage of the device you are trying to run? Its possible that its too big for the inverter and its running hot.
Feb 09, 2014 | Whistler 2000w Power Inverter
How to adjust the Rated Motor Current in keb combivert f4-c. I cannot understand in manual
Run the motor with no load to see if it functions with no load.
If the system functions with no load, you may still need to increase your acceleration time to reduce the current demand.
What is the part# / serial# of the inverter in question?
Dec 28, 2013 | Inverter KEB COMBIVERT F5
My inverter keeps going to falt even though i only use it for a few seconds its only a few months old and has not been used mush its a 1000 2000 max
What are you trying to power with the inverter? Do you know how many watts your appliance need to run? Your 1000 watt inverter needs 83 amps from your battery to drive a 1000 Watt appliance. The minimum size wire you need to hook up the battery to the inverter is a size 6 as short as possible but no more than 25 ft.
Jul 28, 2011 | Inverter 1000-2000w Peak Surge Power
Can you daisy link two inverters together positive to positive neg to neg ac out to increase the watts
This will cause big problems. It will not work and will likely cause both inverters to fail. Power inverters must create the 60Hz sign wave from a crystal controlled internal frequency driver. It's like a clock that keeps the timing at 60Hz. 2 independent units will have slightly different clocks both in time and frequency. This would cause the output waveform of one unit to be out of phase with the second. If they are out of phase, they will look like loads to each other and likely fail. It would be possible if the inverters had a way to link their clocks or use only one clock. This could be designed in however I have never seen this feature. You can hook up multiple inverters to the low voltage side (12VDC), just don't hookup their 120VAC output side. Hope this helps.
Jun 07, 2011 | Inverter 1000-2000w Peak Surge Power
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
What does soft start mean
Soft start will slowly ramp up the current to the load preventing a surge of current from a cold start. It is similar to having an automobile and pushing the accelerator to the floor to accelerate from a stop using maximum engine horsepower. A soft start would be to accelerate gradually from a stop to the maximum engine horse power which would prolong the life of the motor.
May 23, 2011 | Inverter 1000-2000w Peak Surge Power
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
Inverters / Microwaves
A pure sine wave inverter will usually allow a microwave to run quieter and cooler and more efficiently all around.
So the oven has 850 watts of cooking power?
That would mean its power consumption could be as high as 1700W while cooking, but it could surge or spike higher when it first turns on due to the inductive load it offers.
I would think a 3000W inverter should handle that, but that also depends on its peak surge wattage.
As long as the microwave works properly in a normal wall outlet, I'd say maybe it's too much for this inverter and I'd check back with the dealer on this for his input.
Bottom line: Make sure the oven works well in a wall outlet, and check your inverter's peak surge rating.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 11, 2008 | Microwave Ovens
Electronics - Others Logo
127 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
