Question about Coleman Pressure Washer PW0881800
Pw0751310 Coleman electric
Pw0751310 Coleman power Electric washer - There is a switch that allows the pump to turn on when the pressure drops. The switch is not working. I can manually push the switch on but it does not stay on. There is a magnet at the end of the switch. Any answers?
redbeard00
  • 957 Answers
SOURCE: Coleman Powermate pressure washer PW0872400.01
The systems are simple but if they aunt stored correctly(allowed to freeze) or the air isn't purged out of it. It can result in damage to the machine.If water is dripping out of the pump it is damaged. if not then it could be air (purge system), or a damaged or stuck check valve.
Posted on Apr 26, 2009
SOURCE: no power on electric durabuilt 1400 pressure washer
sounds like a pressure switch is sticking. usually causes this problem especially after being stood for a while not used.
have to remove cover to get to pressure switch, remove pressure switch piston clean regrease with silicon grease refit it m and all should be good.
Posted on Aug 01, 2009
  • 88 Answers
SOURCE: electric pressure washer seems to cycle on/off
hi it sounds to me like you have the wrong lance nozzel in remove the lance and try then, regards
Posted on Jan 25, 2010
SOURCE: Where is the pressure switch located on a simoniz
There is a pressure switch to cut the motor once target pressure is reached. I.e. when the nozzle is closed. It's a black cheap plastic thing, right in front of the pump body. It has a white plastic lever to trip the switch. It was sticking intermittently on mine. the simoniz 1600 is quite a cheap peace of ****, needs fiddling around every time I use it
Posted on Apr 29, 2010
  • 1383 Answers
SOURCE: Coleman Powermate pressure washer.
There may be orings in gun but usually not available as a repair kit. Replace the gun with a 5000 to 6000 psi. You will get a much longer life by over sizing gun. If you like to tinker, you can by orings at Lowes in the plumbing department. Lube the orings with silicone paste (also sold at lowes). Good luck
Posted on Mar 17, 2011
Can I fix a pressure washer?
You did not say what the make and model or but it sounds like either the pressure regulator is opening and then sticking or a valve on the pump is sticking
Aug 03, 2015 | Electric Garden
Hi, I have a Karcher K2.400 Electric High Pressure Washer. When I pull the handle nothing happens. When I plug the power in the pump does run a few seconds. I also checked the inline filter and that is all...
There is a pressure switch that turns off the pump when it gets to a certain pressure. It sounds like that switch is sticking. The contacts should be closed when you first turn on the pump. If you hold open the trigger when you first turn on the pump and the pump stays on then that pressure switch is most likely the problem. If you turn on the pump with the trigger open and the pump runs for a few seconds and then turns off check for a blocked nozzle.
Jul 28, 2014 | Karcher Electric Pressure Washer - 1600...
Coleman Powermate pressure washer. Model PW0751310 A lot of water leaks out in the handle where you squeeze for the unit to work, thus the power spray is weak at best. Took handle/arm apart and didn't...
Mar 17, 2011 | Caterpillar Cat Pump Pressure Washer Pump...
Coleman pressure washer won't turn over.
If your pressure washer doesn't have an electric start, then leaving the switch in the on position would have done no harm. (It might have done no harm even if it does have electric start, but that depends.) Your most likely problem is gummy gas residue. Have you tried a spray starting aid like "instant start"? If you get some firing with that, but does not keep running, then your gas supply is clogged, probably at the needle valve that operates via a float. If it keeps running, then you may have cleared the clog already. In any case, be sure to use a gas preservative like "Sea Foam" or similar to prevent this headache in the future. If you found this useful, please vote. Thanks.
Feb 16, 2010 | Northstar Gas Powered Wet Steam & Hot...
Where is the pressure switch located on a simoniz 1600 electric power washer?
Sep 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
Apr 26, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Coleman 5Hp Compresser
All electric compressors share a basic design with ac power pressure switch with unloader and checkvalve between the pump and the tank. When the pressure switch powers off, it unloads the compressor by releasing the air in the discharge hose. You will notice a small tire stem pin and a lever to engage it somewhere on the pressure switch. If the compressor stops before reaching set cutoff point, the air pressure remains in the discharge hose not allowing the motor to start, thus the hum you hear. Solution is to check for the proper function of pressure switch /unloader, tank check valve (if check valve leaks air back to compressor it will load motor causing hum) and extra measure check capacitor for at least 90% of rated valve. Finally, do not run this compressor with an extension cord, use more hose instead. enjoy
Oct 22, 2008 | Coleman CP0302013 20 - Gallon Portable...
Coleman Pressure Washer PW0881800 Logo
202 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
