TROUBLE REPLACING OEM TIMER - UNIVERSAL ELECTRONIC FAN TIMER
I REPLACED AN OEM ELECTRONIC FAN TIMER WITH A UNIVERSAL ELECTRONIC FAN TIMER, BOTH FROM HONEYWELL, AND THE RECOMENDED PART BY HONEYWELL. THE CROSSOVER REPACEMENT TIMER RECOMENDED BY HONEYWELL. THE WIRING DIAGRAM TO REPLACE THE OEM TIMER. I HAVE CONTROL 24V. TO THE CONTROLLER BOARD BUT NOTHING OUT OF THE T-STAT R TERMINAL ON THE NEW TIMER BOARD.
    President:
  • 1,515 Answers
Hi, you should be real close with the universal timer and the factory OEM. On the new control board, if you have 24 volts to the board, you should have 24 volts from R to ground or to Common. I know that on most all control boards the voltage in is 120volts as you will have terminals for L-1 and L-2 to run the high voltage controls from the board and all of the thermostat control terminals in a row, R,G,Y, W, C, and so on are 24 volts. 120 volts is stepped down to 24volts control and you say you have nothing out. Make sure you have 120volts in. You are calling this a timer board, is this a heat-pump defrost board with the 3 settings and pin to defrost the unit at 30,60,and 90 minute times? This is what it sounds like. If all was terminated per diagram, you would have the 24 volts required to fire this unit. These defrost timer boards require high voltage to them as well. Even though the board is a new board and you know for a fact that it is wired properly, it may be a defective board. I have seen this many times in my years as a tech. I have shorted new boards out by static electricity and by mis- wiring one. You can kill power and look at the back side of the board to see if this has happened. Sometimes you will find that they missed a solder point on the back side not completing a circuit through the board. To give you more ideas, I would need to see the diagram, or if you could send me the model, serial, and name of your unit. The board number would help also. Check out what I have said and get back to me on this. I will wait to hear.
Shastalaker7
Posted on Jun 06, 2010
Is there a substitute fan motor available for my Emerson Quiet Kool dehumidifier?
OEM part numbers are problematic. If you are capable of removing/replacing it yourself, it may come down to taking it to a supply-house like Grainger or Johnstone and having a parts guy just physically match it up. Magnetek/Universal has a rather VAST line of products. In Akron, Ohio, we have Home Appliance Parts that are nearly psychic, so don't discount the appliance guys on the small stuff!
Oct 10, 2015 | Emerson Heating & Cooling
Hotpoint hm315ni
Is there power to the compressor relay? Check Thermostat (or controller if electronic), defrost timer, compressor relay. If power all there, compressor needs replacing. Also check it hasn't just overheated due to faulty fan or dirty condenser
Apr 28, 2014 | GE Refrigerators
Just replaced toner K and now says empty
You replaced the Cartridge with a OEM product or third party or a refill. if the last the electronic chip on the toner cart is still telling the machine the cartridge is old so refilling will never work replace the cart with OEM cart,
Apr 27, 2014 | Konica Minolta Magicolor 4690MF...
Fantech FD60EM electronic timer control makes a loud buzzing sound and does not operate the fan
This timer appears to be Leviton LTB60
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Timer has 1 year limited warranty, evidently from manufacturer.
If timer is making humming sound, then it is defective, possibly receiving undervoltage on the line, or wiring installed incorrectly.
Switch noisy timer with one of the other timers, and see if problem follows the timer, or is related to the specific location.
Otherwise replace with LTB60 from Amazon for $24.
Or buy Intermatic Ei200 timer, or replace non-electronic with spring-wound timer such as 60-minute Intermatic FD60, or 30-minute FD30, etc.
Nov 18, 2012 | Fantech FD60EM Electronic Timer Control
Why won't the fan motor shut off on my 1991 acura legend?
Hey chandralebea,
Try first by replacing the cooling fan engine temp sensor switch, as this may be the cause.
Good Luck
Jul 29, 2012 | 1991 Acura Legend
I nees 15 min. timer for my Newtone bathroom heater. I live zip code 94602 Oakland, Ca. Where to find. Thanks
You need "15 minute countdown timer" for a bath fan.
1) Following page shows selection of timer types and brands:
http://waterheatertimer.org/Countdown.html
There are push button electronic types and rotary dial types.
2) Easiest to wire is mechanical spring type countdown timer, FD series.
No electronics that can be affected by 'electric noise' on fan circuit.
Intermatic spring-wound last for years without problem.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers/fd15mc_w005485.php
3) Another reliable timer is GE 15088 sold at Home Depot.
Timer has preset for 20 minutes, not 15
http://www.homedepot.com/webapp/wcs/stores/
4) Amazon sells reliable 15 minute Intermatic electronic countdown:
http://www.1000bulbs.com/product/3293/ELEC-EI200LA.html?utm_source=SmartFeedAmazonProduct
5) Timex sells 15 minute spring wound countdown timer. Lower price is probably with reason since Timex are generally sold in drug store/dollar store rather than hardware/electric outlets.
http://www.amazon.com/Timex-Minute-Springwound-Countdown-Timer/dp/B00013K69Q
6) Spring wound timers connect easily to same wires that come off old fan switch.
Old switch has 2 insulated wires, connect them to either terminal on spring wound timer.
7) Electronic timers are wired differently:
Instructions for wiring electronic timers appears on following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15088
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Remote fell on floor, won't work replaced battery, no help
try replacing battaries, but unless you have circuit board training on how to repair broken connections i would just go get a nice universal remote and tape pillows to it so you cant break it.. .:P
http://reviews.cnet.com/best-universal-remotes/
Jun 22, 2009 | Universal Remote Control Hampton Bay...
Samsung RS267LABP Side by side refrigerator
I WOULD SAY THE NOISY FAN WAS DUE TO A BUILD UP OF ICE ON THE EVAPORATOR.THE ICE MIGRATES AND EVENTUALLY IT TOUTCHES THE FAN BLADE. PERSONALLY YOU COULD HAVE A PROBLEM WITH YOUR DEFROST CIRCUIT.NOT SURE IF YOU HAVE THE ELECTRONIC TIMER OR MECHANICAL TIMER WITH ASSOCIATED COMPONENTS.IF MECHANICAL, I SUGGEST YOU REPLACE BOTH THE THERMAL FUSE AND THE EVAP.CLIXON. IF ELECTRONIC, A LITTLE MORE COMPLEX. EQUIPTMENT IS NEEDED.
Aug 16, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
