Question about Toro Lawn Mower With Toro Power Tools
We have Toro Lwa 100 Lawn Mower Model #26623. Power engaged, start mowing but lawn mower will not cut grass. You have to stop and let it rev up again to cut more grass.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 338 Answers
This 1991-92 model is equipped with a blade brake clutch. When the blade slows down this means the belt is slipping. This slipping can be caused from a few different things.
1 --A loose cable. We have Toro Lwa 100 Lawn Mower Model  #26623. - barterjoe_0.gif
Try adjusting the blade cable on the upper handle. this unit has an adjustable section. make sure the cable is not so tight that you snap it.
2 --A sticky pivot point under the belt cover
The belt cover in the back builds up with dirt and debris. Make sude it is clean under the cover and all of the pivots move freely. ( do this with the engine off)
3 --A sticky belt tensioner under the deck cover
The underside of this machine has a metal cover to protect the belts. Remove it and check that the blade belt idler arm is not frozen in place. this will cause the belt not to enguage all the way.
4 --A worn belt or belt pulley
The large flywheel and pulley can wear. Check this if the belt looks good.
This is all there is to the machine BBC system.
I hope this helps.
Get parts and more diagrams at a Master Toro Dealer like www.arcolawn.com
Posted on Mar 02, 2011
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
Toro Recycler engine doesn't rev up when control arm is engaged
check the throttle spring in the front of the engine.It is hooked to a loop and when going near a bush it will push in and slow the rpms down.If you locate it pull it out and the RPM"s should increase.
Jul 25, 2012 | Toro Power Lawn Mower
My toro walk behind self propelled blade disengages how do I adjust it
No adjustment, ensure no obstruction on drive end of cable, replace cable, probably stretched over time.
Jun 17, 2012 | Toro Power Lawn Mower
Toro 20022 grass buildup
at tractor supply has a paint called slip
May 25, 2012 | Toro Power Lawn Mower
I have a Toro 22 in Recycler Lawn Mower Model No. 20331 I can't pull the starter cable, it seems locked. My boys were mowing the lawn earlier, some very high grass, and the mower stopped
Hi. It's not locked. The piston has siezed up maybe for lack of oil or sitting too long. It is time to retire it. If your son or daughter or grand kids has some mechanical in them. They can tare it apart and fix it. Good luck.
Jun 25, 2011 | Blount International Oregon Gator Mulcher...
Grass cutting blowing out from in front of mower deck.
Dull or bent blades can cause this. Make sure that the grass is not built up under the mowing deck. You can purchase new blades at a Toro dealer like www.arcolawn.com.
tell them Joe from Fixya sent you!
Feb 12, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
808 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
