Question about Dell 810 All-In-One InkJet Printer
Printing problem anything I print gets a full covering of yellow as a background. how do I correct this
  • 3 more comments
  • Anonymous Jun 22, 2008
    how do I correct this?
    Printer: Dell 964
    b_bhagya_laxmi@yahoo.co.in
  • lakshmi1 Jun 22, 2008
    Printer: DELL 964
  • Anonymous Jul 22, 2008
    everything I print is highlighted in yellow and everything I print is in in red. This is a brand new printer.
    everything I print is in red and is highligted in yellow
  • peacelilly Aug 07, 2008
    everything i print comes highlighted in yellow
Take the p.o.s back
Posted on Aug 07, 2008
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Yellow not printing in Canon iP6600D printer
in the print out alone you can already know what print head is no working properly like missing color. if cleaning is not solving the issue this purging the print head. just read the user manual for the instruction
Apr 29, 2013 | Canon Pixma iP6600D InkJet Photo Printer
Brown background instead of white
You are probably out of ink in one or more cartridges. You need to do a diagnostic print and take the print to the ink supply vendor to get the correct replacements.
Oct 03, 2012 | Kodak Office Hero 6.1 All-in-One WiFi...
Phaser 7300 dn prints full yellow color background on every page even if the background copy shows no color.
Most likely the yellow drum unit is causing that problem. The charge roller gets worn and makes whatever color it is in print out all the time. That would require replacing the yellow imaging unit.
Feb 20, 2010 | Xerox Phaser 7300DN Laser Printer
Extra background color in my printing
You really should not run labels through this machine unless they are full sheets. If you are running used pages the glue will build up on the tranfer belt and cause the hazing.
Jul 28, 2008 | HP Color LaserJet 2600n Printer
Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Jun 08, 2008 | Dell 5100cn Laser Printer
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Background Color
1) In the Applications Menu on your copy screen there should be a option to turn on or off a background color fill. Turn it off and try. If it still comes out try hitting panel reset. If this doesnt work. 2) You have a bad Image Unit. Change the yellow image unit. 3) You may also have a bad write unit. Pull out the four write units and check the yellow write unit. It may have gone bad in which case it needs to be replaced.
Jun 12, 2007 | Minolta CF1501 Copier
Yellow on all color printings
What photo program do you use? Is the yellow background on all Word doc's? You should check WORD go to the Format|Background make sure "no fill" is selected. You should also check your print properties in control panel and any special program DELL uses. Make sure there isn't some custom setting that is printing the yellow background. Let me know what happens. Good Luck, Tim
Feb 18, 2007 | Dell 962 Photo All-In-One InkJet Printer
Dell 810 All-In-One InkJet Printer Logo
55 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
