Question about Lexmark X1270 All-In-One InkJet Printer
One colour will continuously stop working but will start again when print heads are cleaned
  • sedge1508 Jun 07, 2010
    I have used two lexmark 26 genuine cartridges, and both have had the same problem, in that they both worked perfectly on installation but after a few prints the red stopped working and then only started again after the heads were cleaned using the maintenance tool in the lexmark solution centre.
    Genius:
  • 1,087 Answers
Great job on cleaning the printheads! But if you're routinely cleaning the printhead, there must be something wrong either with it or with the printer itself. Either ways, I strongly recommend you contact Lexmark Technical Support for them to look further into this problem. Genuine Lexmark cartridges shouldn't cause you that much trouble.
Posted on Jun 09, 2010
Replaced ink cartridge- still not printing! help
When the printer is not indicating you need to replace a cartridge, and it is not printing good, most of the time the print head is clogged. Run the head cleaning program several times and if that still not works, remove the cartridge and put a drop of clean water or printer cleaning fluid fall in the nozzle, you see down where the cartridge was seated.
Then print a few pages, with the colour that would not print and continue till you see the colour come back again.
switch a ink jet printer on at least once a week. During startup the printer will perform a cleaning cycle. After a few minutes you can switch of the printer. This could keep the front heads clean for a long time.
Success
Mar 23, 2015 | Epson Expression Home XP-410 Small-in-One...
Printer has stopped printing in black
Car,
Remove the print head and cartridges.
Take 1 ounce ammonia to 7 ounces of hot tap water ,mix in bowl and let the head set in it for 30 minutes.
Ink ports in the solution.
Thoroughly dry the head and re-insert.
Do a deep clean and try again.
If that does not work remove head and spray some WD40 on the head eject nozzles.(head upside down)
Be careful not to get the WD on any rubber part.
Mar 22, 2014 | Canon PIXMA iP4200 InkJet Photo Printer
The colours are totally wrong on printing
First of all the print head is clogged just because you have tried to print repeatedly while some of the cartridges are empty. This results ink burn in the nozzle and clog. My recipe: Heat some drinking water in the kettle (70-80 C). Put the head in it and shake gently several times until ink is completely clean (10 minutes). Change the water do the same again. Change the water again (70-80 C) this time put a spoon full of apple vinegar (becomes a natural acidic solution very dilute) shake again, clean with cotton stick. I did it and started to love my mp800 again as much as I just bought it, all colours come back and started to print superior photos again...... Do not touch heads' copper poles and cartridges poles because of the static electric they may mulfunction and colours may becaome totally mixed for a short while...
Dec 26, 2010 | Canon Pixma MP800 All-In-One InkJet...
Wont print in black at all even after numerous cleans etc and new catridge. Colour is fine though?
* Buy alcohol solution (70% or more). You can find it in any drug store.
* Remove both cartridges from the printer head. Unplug the printer head from the printer body. Pour the alcohol into paper towel layer.
* put the printer head on the top of wet towel with the face of HEAD touching the towel.
* clean the head with the towel and get rid of all the built-up ink on the head.
* Pour the alcohol into the printer head container (ink-receptacle area is where the ink cartridge normally sits, notice a small hole where the ink flow into the printer). Do not touch any electronic parts and let it dry over night.
* Do step 2-5 again if necessary.
* Install the cartridge back to the printer and run several head cleaning maintenance, print nozzle check, make sure to repeat this step until no more dead nozzle shown.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 12, 2010 | Brother MFC 6490CW InkJet Printer
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Red colour not printing - all others OK
for that you will have to open the printer and remove the head unit,and clean it with moist tissue and alcohol. thanks.
Nov 07, 2008 | Brother DCP 115C All-In-One InkJet Printer
C6180 stopped printing black
press setup button then go to tools then select clean printhead
Jun 05, 2008 | HP Photosmart C6180 All-In-One InkJet...
Not printing black
Aug 22, 2007 | Brother MFC 210C All-In-One InkJet Printer
Will not print some colours
Rhis seems to be a printer Firmware problem, Nothing for it but to bin the printer and start again.
Nov 13, 2006 | Canon BubbleJet i9950 InkJet Photo Printer
Lexmark X1270 All-In-One InkJet Printer Logo
428 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
