Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
How do you assemble a Hayward pool pump - Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
  • Stephen Dorje
    Stephen Dorje Jun 07, 2010
    What model and HP?
  • 11 Answers
If it is completely apart, I am guessing you were replacing the motor? Anyway, motor gets mounted to the mounting plate plate by way of four bolts through the mounting plate into the motor. There is an top and bottom to the mounting plate usually indicated on the plate. Next goes the seal plate, there is a top and a bottom as well, usually indicated on the plate, also there is a **** in the seal plate at the bottom, an opening so if the shaft seal leaks, the water has somewhere to go instead of to your motor to rust it out. There are no bolts for the seal plate, it is held in place by the impeller. You need to get a new shaft seal before you do all this (SPX1600Z2), any compitent pool company should have a bunch of them in stock. Shaft seal is two pieces. The white porcelin piece with a rubber gasket around it goes over the shaft and into the seal plate. It fits snug in the seal plate and does not touch the metal shaft of the motor. The other half of the shaft seal goes on the impeller. The side of the piece of the shaft seal that is all black, with no metal, does not bump up to the impeller, it eventually will touch the white porcelin that is now in the seal plate. That black part of the shaft seal that goes on the impeller is made of carbon and can break somewhat easily so don't bang it on anything. You have to wiggle that part of the shaft seal onto the impeller with a little elbow grease. Make sure it is seated all the way on the impeller. Now you can screw the impeller on the the motor shaft. The motor shaft will want to spin on ya so you have to take the back of the motor off and hold the shaft. Should be a 7/16 or 1/2 inch wrench depending on what motor you got. Snug the impeller up while holding your wrench on the shaft. Doesn't need to be a death grip, the motor will actually tighten the shaft seal more due to the direction that it spins. Now the seal plate should be imobile after you tightened the impeller on. You now put the diffuser on to the seal plate. It also has a top and a bottom usually indicated by some writing. The diffuser has little nobs on it (for lack of a better term) that correspond with female groves that accept the nobs located on the seal plate. It just sits there in those groves, no bolts of screws or anything. Lubricate the gasket on the pump housing before you slide everything back into it. And make sure there isn't any debris that's gonna pinch between the seal plate and the gasket. Slide the whole mechanism into the pump and the seal plate should meet flush with the rest of the pump and tighten to it by way of four bolts (9/16"). When sliding that in there you can take off the pump lid, remove the skimmer basket, reach through the whole and guide the diffuser to the hole. Get those four bolts well snug, but if you tighten too much they will start to recess into the housing which aint a huge deal but you don't really want to go too far down that road. I hope thats all understandable, maybe i went into too much detail but I have taken apart and put back together so many hayward pumps that I have learned all the little things that potentially go wrong......good luck!
Posted on Jul 14, 2010
Hayward pro series s244 im getting large amounts of sand in pool and the system is drawing lots of air what could be wrong
Either broken lateral drain assembly or the manifold.
If fairly new filter, it could be that you have overfilled the amount of sand, as it is too close to the bottom of the variable position Multiport filter valve.
Hayward SX244DA Lateral Assembly With Pipe
May 24, 2015 | Hayward Industrial Products Hayward Pro...
Hayward pool filter Model SP711 alignment on filter, ports, spider gasket replacement
Remove the 6 screws from around the valve assembly. Pay close attention to the current orientation of the valve assembly before removing. Lift the value assembly straight out and the spider gasket is on the bottom. This could be twisted a little which would also cause your back flush port to leak when positioned in the filter position. If twisted, just position back in alignment with the valve holes on the bottom of the valve assembly. If the gasket is worn or torn then just replace and place the valve assembly back in the valve housing and replace all 6 screws. If you still have problems with water not functioning based on the way you have the handle turned then it might be time to replace the entire valve assembly.
Jun 15, 2014 | Hayward SAND FILTER, PRO SERIES
Pool pump squealing
sometimes the gasket from the wet side of the pump fail and the pool water enters the bearing assembly of the pump. if there is a descent pump store, they can change the bearings within an hour. otherwise, a new pump is the solution
May 31, 2014 | Hayward 1.5hp Max Flo Inground Pool Pump #...
I have the Hayward EC-40 Filter, my problem is the DE is getting into the pool. What would cause this?
Broken/torn grid, o-ring bad in the housing by the grid assembly or grids not in manifold properly. Backwash, open the filter, remove and inspect the grids (the plastic bases too).
Jun 05, 2010 | Hayward EC-40 DE Pool Filter with pump
On my Hayward ProGrid filter there is water leaking from the air release assembly? What can I do
If it is the assembly (the piece that the pressure gauge and relief nut screw into) that is leaking you would need to replace it, it is about $90.
If it is where the assembly attaches to the top of the filter head you can replace those O-rings ($10-$15) then clean and re-teflon the male threads.
Aug 25, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
737 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
