Question about Casio Exilim EX-Z77 Digital Camera
I have a Casio EX-Z77 camera. When I turn it on the screen is blank. I can shoot a picture and the flash will work but nothing shows on the screen? Any suggestions of what can be wrong? The camera has been well taken care of and has never been wet.
  • mwrobbel Jun 06, 2010
    Yes it was very helpful and prompt!
  • 10,594 Answers
Here are two scenarios for this kind of problem, please check camera carefully as mentioned below and do the needful:
1- Camera does not show live view in camera mode to take fresh picture but shows old/ previously stored pictures in playback mode correctly. These symptoms show problem of ccd imager chip failure in camera and ccd imager chip need to be replaced by local camera repair shop because it needs expertise.
2- Camera does not show live image in camera mode nor shows old/ previously stored images in playback mode and lcd screen remains blank/ dark always however camera takes fresh picture, flash works and taken pictures look fine if transferred in computer, that means LCD Screen is defective and rest of camera is fine. Replace lcd screen to fix the issue.
Hope these info will help you to determine the camera problem.
Thanks.
Posted on Jun 06, 2010
    I think it is the first scenario. Is it worht fixing or should I just buy a new camera. It is 3 years old.
  • Shahid Electronics
    Shahid Electronics Jun 06, 2010
    Repair would cost you around $80 or so in local camera repair shop, now you can decide easily to get it fixed or not.
My Casio Exilim Z77 fell from a table while it was on and the lens was out. Now when I turn the camera on, everything seems to be working fine, but no picture is shown on the screen. The display is all...
Sounds like a ribbon cable from the CCD (Lens assembly) got knocked loose from the board. If you're handy I'd give it a shot, look for a small gold colored thin ribbon like cable, there should be a few, check the connections at both ends and reassemble.
The 7.2 megapixle Exillim is over 4 years old so your warranty has to be over anyway, you have nothing to loose.
You can get a much better camera for under $100 these days.
TickMagnet
Aug 15, 2011 | Casio Exilim EX-Z77 Digital Camera
Casio EX 277: Turn camera on. Menu shows on screen but display is black. No image shows.
This camera is great and fits in any pocket! I thought mine was dead when it started acting up. Check these folks out: http://www.teleplancamerarepair.com/manufacturer/casio.asp
The cost of repair was a third of buying a new one.
Jul 08, 2010 | Casio Exilim EX-Z77 Digital Camera
Nothing shows on viewing screen
I had something like this occur with a minot mini video camera only it locked up in the "On" setting, meaning I could see a display on the screen but could not turn it off. I suggest you look very closely for a reset hole at the bottom somewhere, a place where a safety pin or the straightened end of a paper clip could be inserted. If no Reset can be found, then try holding in the Power On/Off for as long as 90 seconds. This may clear the problem. I would also suspect no power due to low charge or no charge on the battery, battery installed incorrectly, or battery not charged up.
Dec 10, 2008 | Casio Exilim EX-S600 Digital Camera
Need a new screen, for crakced casio exilim ex-z77
Hello Brandi.Here's you replacement LCd screen.
http://cgi.ebay.com/CASIO-EXILIM-EX-Z77-LCD-SCREEN-PARTS-%2F-REPAIR_W0QQitemZ250330962465QQcmdZViewItemQQimsxZ20081124?IMSfp=TL081124134001r12156
See ebay has all you ever need.
Cheers,
Sai.
Dec 07, 2008 | Casio Exilim EX-Z77 Digital Camera
OVer exposure
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
CASIO Exilim EX-z77 曝光過度 plz use google translate
www.mydc.com.tw
Jul 07, 2008 | Casio Exilim EX-S600 Digital Camera
"check connections"
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Jun 28, 2008 | Casio Exilim EX-Z77 Digital Camera
Casio ex-m2
Does the Camera have internal memory? I think you need the card it to get any where Check out the manual
Dec 11, 2006 | Casio Exilim EX-M2 Digital Camera
Casio EX-Z57 Flash not working
Try resetting your camera and see if that helps. Sometimes it does. In REC mode press menu go to setup tab go up to reset press right arrow & highlight reset press set. If that doesn't work you are probably going to have to send it in.
Oct 29, 2006 | Casio Exilim EX-Z57 Digital Camera
Casio Exilim EX-Z77 Digital Camera Logo
60 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
