Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How do you adjust a 42 inch deck on a craftsman riding lawnmower
  • 86 Answers
SOURCE: won't go into gear
What kind of transmission is it gear or hydro ? What do you mean by not going into gear ?it wont move or you cant put it into the position such as 1,2 or f,r ?
Posted on May 09, 2009
RonPark
  • 855 Answers
SOURCE: my deck is way too low. How do I adjust it?
Your mower should have a lever on it that you move to raise or lower your deck. The lever will normally have the slots that it locks into numbered like the trans gears if yours is not automatic.
Posted on Nov 06, 2009
huffman49
  • 235 Answers
SOURCE: where is the choke located on a craftsman riding
the should be a cable near the throttle on the dash by the steering wheel. if not look at the carb there should be a sliding choke on the front of the carb..good luck
Posted on Apr 14, 2010
heatman101
  • 43501 Answers
SOURCE: my craftsman riding lawnmower 42"
The first thing to check is the wheels on the back corners of the deck....amke sure that they are set at the same height and that the bearings are not out of the wheel, which would allow the deck to sink lower on one side.
If all of that checks out then you have problems under the deck....
The bearings that hold the blades can wear allowing one of the blades to drop, or one of the blades could be bent which could cause it to cut lower...to fix that bearings will have to be replaced or the blades will have to be replaced if bent.....
These would be the causes for your mower to cut unevenly...
heatman101
Posted on Apr 09, 2011
rycgl
  • 1545 Answers
SOURCE: I need a manual for
Here is your manual. This site handles all the manual downloads for the Sears products.
http://www.managemylife.com/mmh/owner_manuals/17008/CRAFTSMAN-Lawn-Tractor-L0709142?brand_name_search=+917.255440+
Posted on May 22, 2011
I need the routing for my craftsman 19.5 hp 42" 6 speed riding lawnmower belt.....model no#917259561
Hi and welcome to FixYa, I am Kelly. From the model number this is an EZ3 riding mower.
The steps are in the manaul here ander service and adjustments: (Page 22)
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0408255.pdf
The routing is the same in this manual on page 23 and has a much better diagram.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0308079.pdf
Also look on this page: (2nd set of pictures for 42 in decks)
Electrolux Home Products (EHP / AYP / Craftsman)
http://opebycrigby.tripod.com/decks/ehpdeck.html
There are many more decks at the top of the page. You have to click the links
Hopefully this is what you needed, Thanks for choosing FixYa,
Kelly
Jul 17, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need your assistance please
http://www.superxpower.com/pages/parts/viewbybrand/default.aspx
try this link, they don't deal specifically with craftsman parts, though they do have aftermarket suitable substitutes for craftsmen. This website has excellent illustrated parts breakdowns for numerous other riding lawnmowers though and I'll bet that something like MTD or White Outdoor is exactly the same as your mower. I have a White outdoor 42 inch riding mower and have changed numerous parts using these illustrations. Good luck
Apr 14, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Where is the choke located on a craftsman riding lawnmower? 42" deck
Mar 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
348 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
