My pdf file of my computer will not open, a sign says "This file is not supported or you don't have the latest updates to Photo Gallery" it was working fine till last week. Keynan was a great help with my last question. can you help me?
  • Jack Woolfe Jun 16, 2010
    I very much appreciation your help and patience.
    Sincerely Jack
  • 532 Answers
Photo Gallery refers to Windows Live Photo gallery. This shouldn't have anything to do with opening a PDF file. The most common PDF viewer (Reader) is Adobe Acrobat Reader, available free form Adobe.com.
If you already have Adobe Reader, you may need the latest version.
  1. Go to Adobe.com.
  2. Click on Get Adobe Reader
  3. Uncheck the checkmark that says Also Install Free McAffee Security Scan Plus.
  4. Click DOWNLOAD (Big Yellow Button.
Make sure you follow any allow prompts etc to install this.
Reply if you need other help or if this does not resolve the issue.
Posted on Jun 06, 2010
  • 27 more comments
  • Circe Denyer
    Circe Denyer Jun 06, 2010
  • Jack Woolfe Jun 07, 2010
    After following your advice I got a sign that said "The following application could not be installed
    Adobe Reader"
    What do I do know?.
  • Circe Denyer
    Circe Denyer Jun 07, 2010
    What version of Windows are you running?
    What model of PC are you running?
    These may sound like left field questions, but, it helps to advise you.
    ALSO:
    Check to see if you have Adobe reader installed.
    Click start
    Click Control Panel
    Click on Programs (or add remove programs)
    Look for Adobe and reply with the names and versions of any programs you have installed.
    Thanks for using FixYa.
    Windows version: 6.0
    Model of PC: ASPIRE:M1641
    Installed: Adobe reader 9.3.2 cpsid 53951
    Regards Jack
  • Circe Denyer
    According to the Web, your system has Windows Vista, and Adobe Reader installed.
    • OS Provided Microsoft
      Windows Vista , Microsoft Windows Vista Home Premium
    • Software eSobi , Acer Arcade Live ,
      Microsoft Works 8.5 , Adobe Acrobat Reader , NTI Media Maker (OEM) ,
      Acer Empowering Technology , McAfee Internet Security Suite (Trial) ,
      Microsoft Office 2007 Home and Student Edition (60 days trial)
    According to the list you have Adobe Reader. I cannot tell what version you have.
    Please do this for me and send me the results.
    1. Click Start
    2. Right mouse click while hovering over Computer
    3. Select Explore from the drop down list
    4. Click once on the title Documents in the upper left corner. See picture:
    5. Look at the list of documents and tell me if you see any files that are named XXXX.PDF or pdf
    • If yes, what does the border and icon look like? Is it red? See picture:
    • If no, what does it look like? Color or none, shape of the icon, does it look like a file or is it blank?
    1. Right click on the picture and tell me what the information shows in the context menu.
    Report back to me with this information. The line I need is Open with...
    Where your screen has
    Pictures
    Public
    Documents
    My screen has
    Music (1)
    Music
    Pictures
    I clicked on pictures, it brought up my files.Quite a lot of pdf, as I had bean working on them for some time.
    No files starting xxxx
    The icon on the pdf files is not the same as your red icon. that red icon is on my desktop & on my start menu, not on the pdf files.
    Trying to describe the icon on the pdf files is a big test for me, I will do my best.
    Very small, a taped blue pin with a small red ball on top, on the right side of the pin is a blue square with a red mark.
    When hovering over the icon to describe it a sign said (docx file) I Had not noticed it before.
    Regards Jack
  • Circe Denyer
    My apologies for saying look for xxxx.pdf without explaining xxxx is generic for any filename.
    The information you gave me tells me that the PDF files are now associated with Microsoft Word.
    Right click on any file in your documents list and select Open With.
    The next Window will tell you which program is associated with this file.
    At the bottom of the Window, you will see a statement that says: Always use the selected program to open this kind of file and there is a large browse button at the end of the window.
    Click on the BROWSE button
    In the dialog box select Adobe
    Double Click on it
    You will see a folder that says Reader ( or ) Acrobat
    Double click on this
    You will see a list of files.
    Locate the file that looks like
    Double click on it.
    The original window opens back up and now the Adobe program is set up to open PDF files.
    Check the box that says "always use the selected program to open this kind of file.
    IMPORTANT:
    If when you click through the folders for the Adobe program, you see the word Acrobat and not Reader, follow that set of folders to select the Adobe program. It will mean you have installed Adobe Acrobat - the program that allows you to edit the PDF files.
    Good luck. I will be checking your response to see how you are doing with this information.
  • Circe Denyer
    Circe Denyer Jun 08, 2010
    The docx indication you see is the default extension for files in Microsoft Word version 2007.
    Files are structured filename.extension A PDF file is Filename.pdf. a Word file can be Filename.DOC, filename.docx or filename.rtf
  • Jack Woolfe Jun 08, 2010
    Trying to follow your last message.
    No Adobe Reader 8.1 clicked on Adobe Reader 9.3
    No icon or file name lacro32.exe. the options are:ecl,Reader, Resource & Setup files, clicked on Reader.
    I followed instruction regarding browse & Adobe Program.
    Now most of the icon's on my documents have changed, a lot to the red adobe and to xps which I had not seen before.
    Should I install Adobe Reader 8.1?
    I still can not open, save or send pdf files and I have many. It was my mane occupation.
    Regards Jack
  • Circe Denyer
    Do not install Adobe 8.1. Adobe 9.3 is newer and it was the one installed .
    Please clarify these items for me:
    1. What error do you get when you double click to open a PDF now? Is it the same as the original message? Please copy it in your response.
    2. When you right click on a PDF file, do you see Open with Adobe Reader 9.3? If not, what does it say exactly?
    3. Can you double click on the red Adobe icon on your desktop and open the Reader program?
    4. You say you cannot open, save, or send PDF files. Do you edit them? OR do you just read them?
    5. Go To Start - Type adobe in the Start Search box that appears just above the start button
    6. List for me the programs a\that appear above the pop up, like this.
  • Jack Woolfe Jun 09, 2010
    Sir
    Twice I have almost finished with the answers to your questions when it is lost, it is a long answer.
    Can I submit my answer by email or is there a way of saving as I go, or do you have any suggestions?
    Regards Jack
    Sir
    Before answering your questions, I must tell you.
    After answering your last set of questions my computer played up.
    I couldn't get into desktop, I couldn't bring up any files, and other problems.
    I used backup and restored the computer to how it was before my first question to you.
    This is not a complaint, it may have been my fault. I am mentioning it as it may be a help for you to know.
    1. "Photo gallery can't open this picture. The file format is not supported, or you don't have the latest updates to Photo Gallery"
    The answer is the same for photo or document.
    2, No. "Preview,Print, Ace, cDataSecurity, M Scan, Open with, Share, Send to, Cut, Copy, Create Shortcut, Delete, Rename, Properties".
    When clicking on "Open With" Adobe Reader 9.3 is an option,
    3. The Reader program dose not open
    4. There is no option to edit them, that option is available to all other files.
    5 & 6 Just on top of the start button has 5 old email from me.
    On top of start list now has "Programs" Then Red Adobe icon "Adobe Reader 9 installed"
    Then pdf icon "Adobe 2" Then "Adobe 8-6-10=pdf" A blank icon then "Adobe Reader 8" then "Licence Adobe 9.0" Then just as usual.
    Regards Jack
  • Circe Denyer
    Circe Denyer Jun 09, 2010
    You say your computer had to be restored to an earlier backup. Did you use Windows restore? If so, you may want to try restoring to an even earlier time. Use this only if the information below is not valid.
    Restoring to an earlier time will not fix this if the information regarding the form of Adobe you were using is true. See below:
    From the list you gave me it appears that you had Adobe Acrobat 9 (licened version). This application is a paid version and requires a license. If you did not pay and receive a license, you could have been using a trial version. This trial would run out and stop functioning. This would explain the sudden change.
    If you were editing PDF files, meaning you were making changes to their form and content, you were using Adobe Acrobat, not Adobe Acrobat Reader. If you did pay for Adobe Acrobat, then you should have a digital (downloaded) or disk copy to reinstall it.
    Your PC may have come with this trial version of Adobe 9.0.
    To check on the status of Adobe 9.0 license copy, Click Start, then All Programs, then Adobe, then Adobe 9.0, (not reader 9,3), NOW look for an Adobe 9 application and click it. If ths requires a license upgrade you should be seeing a pop up dialog box to this effect.
    Please reply to this and let me know what you discover.
    I did not restore to fix pdf it was necessary to fix other problems and did the job well.
    I don't know if it is windows,it's icon has been on my desktop sense day one, it dosnot mention windows, it says Backup and restore... it's also in my control panel.
    After start and all programs there is no "Adobe" only, there is an Adobe Reader 9 I clicked on it, it brought a screen with 3 ribbons on top and then a large dark empty screen.
    The top ribbon has the red icon with the Adobe logo and says "Adobe Reader"
    The middle ribbon has:File, Edit, View, Documents, tools, Windows, Help
    The bottom ribbon has only 2 icons highlighted, Hovering over the first"Share Documents and collaborate live within pdf files"
    Hovering over the second "Click to create pdf using Acrobat.com.
    I Will not click on then until hearing from you.
    I do wish your company would except screen shots, it would save a lot of corresponding and be more accurate.
    Regards Jack
  • Circe Denyer
    Thanks for the info.
    It looks as if you do not have the full Adobe program. This program is used to Create new PDF files, edit PDF files, and Create forms etc.
    FixYa does allow you to upload screen shots. In this Comment screen you can insert pictures using the small icon that looks like a tree. When you hover over it, it says Insert Image.
    I need to know what you do with the PDF files on a day to day basis. Do you view and print or do you create and edit?
    I am not sure why the Adobe Reader program is not opening the files unless it has become corrupt. When you tried to install it from Adobe.com, you got an error and that is not normal.
    I do not think that clicking on Create a PDF using Adobe.com will resolve this issue.
  • Jack Woolfe Jun 10, 2010
    My main use of pdf is after scanning documents or photo I save to pdf, it displays better than jpeg, later I use the file to attach to emails.
    I do nead to: Add to, Delete from,or change some parts.
    I cant find the small icon that looks like a tree to forward screen shots, please give me more help
    Regards Jack
  • Circe Denyer
    Circe Denyer Jun 10, 2010
    Here is the screen shot of the Comments box. When you type a response, you should see this at the top of the box.
    Do you see this in the comment box where you submit your responses?
    As to the problem, You need to right click on the downloaded Adobe Acrobat Reader installation file and choose Run as Administrator. Let me know if this allows you to re-install the Reader program.
    If this does not work, your system may be corrupted. You can try the following:
    1. Go to Malwarebytes.org, download and install the free malware scanner. Remove anything it finds.
    Reboot and test.
    OR
    Rollback the Windows system to a date prior to this problem. Do this if the Malware scan and removal does not correct the problem.
    Let me know.
    I found the little tree. Thank You.
    After run as Administrator I clicked on "Create pdf using Acrobat.com" and received this reply.
    "The installing of this application is damaged, Try re-installing or contacting the publisher for assistance"
    I then tried to follow your instructions to download and install the free malware scanner, there is a lot of options.
    Would the "MALWARE REMOVAL MADE EASY" be the correct one?.
  • Circe Denyer
    Instructions for Malwarebytes.org:
    1. Go to this link to download the free version.http://majorgeeks.com/download.php?det=5...
    Click on any one of these locations to start the download.
    2. Once downloaded, you will have a file named mbam-setup-146.exe
    Right click to run as Administrator and click through changing none of the settings during setup. The last screen during setup should look like this.
    Allow the program to run and then select Quick scan from the main program screen.
    If anythiing is found, you will see a line written in red that tells you how many infections it found. There will be a box in the lower right corner that says "remove " Click on it to clean your computer.
    Installed Major Geeks. They scanned 130778 items.
    They fond 40 infected.
    I gave the word to fix
    They said they had.
    How does this help with my pdf?
    Regarde Jack
  • Circe Denyer
    Circe Denyer Jun 11, 2010
    Often Malware causes system corruption. What I would like you to do now, is:
    1. Try your PDF files. If they do not work,then do number 2.
    2. Download and install Adobe Reader 9.3. This time the install should work.
    The download location is http://Adobe.com. It is on the front page.
  • Jack Woolfe Jun 11, 2010
    The PDF is not working. I went to install Adobe Reader 9.3.
    After a few function a sign Said :The following application could not be installed Adobe Reader"
    Then Close download Manager.
    The file is not working.
    What now?
  • Circe Denyer
    First try to update the version you have.
    If there are no updates then you would want to rollback your system to a time before this happened. Now that your system is free of Malware, you can rollback safely.
    The other option is to start the Adobe 9.3 application, then try to open a file from the menu.
  • Jack Woolfe Jun 12, 2010
    No new updates,
    My backup system is not working properly (New problem) will only backup a few hours.
    When started 9.3 & clicked on any PDF file the message is same as previous, clicking on any other file the message is (No items match your search".
    What now?
  • Circe Denyer
    Circe Denyer Jun 12, 2010
    I need you to do a step you have already done, but do it now that the malware is gone. That is, right click on any PDF file and choose Open With. Select Adobe Reader. Make sure the checkbox stating always use this program is checked.
    The error you are getting indicates that Photo Gallery was selected and now Windows wants to use that program.
    Also, when you go to Adobe.com, click on Adobe Reader, At what point do you get the message that you cannot install this program? Is it after you download it?
    Can you please write out all the step and message you see when this occurs?
    You should not be getting any errors for a download and installation of this program.
  • Jack Woolfe Jun 13, 2010
    After clicking PDF then Open With. No option to: Always use this program..
    After clicking on Adobe Reader the message comes immediately after clicking on Download.
    After the message clicked OK then Adobe red icon came then "ADOBE READER
    Application Progress Manager
    How can I be sure malware has gone?.
    Regards Jack
  • Jack Woolfe Jun 14, 2010
    PDF File still not working.
    What should I do?.
  • Circe Denyer
    Circe Denyer Jun 15, 2010
    The Adobe Progress manager indicates that the software has not finished installing.
    This must be completed before the PDF files can be opened.
    Does this progress manager ever complete?
    As to the Malware, you can run the Malwarebytes program from your desktop to check it.
    I have installed 2010 PDF successfully.
    Thank you for your help and patience.
    Regards Jack
My friend was using Windows Photo Viewer, and now my desktop I can't open any icons, and when I do it says Windows Photo Viewer can't open this picture because either Photo Viewer doesn't...
There should be files type issue first make sure your photo image open in ms paint if it will open with mspaint then your photo file type is fine but if it will not open there then you need to check file type. For that go to control panel ->folder option then files type . Check that your photo file type will open with photo viewer then apply then check. If still same then need to repair photo viewer because it is corrupt. Let me know if you need further assistance. Thanks for using FixYa.
Aug 23, 2011 | Computers & Internet
I have HP CPU and Windows 7. I've done updates over time. When I try to open an email pdf attachment, I get this message: Windows Photo Viewer can't open this picture because either PV does not support...
So the first thing you will want to look at is 'Where did the image you are trying to view originate from' so images or depending on the type of image the computer program may not recognize it. Also make sure that the program is up to date, you can do that by going to the manufactures website and making sure you have the latest version.
Feb 15, 2011 | Computers & Internet
I need user manual for Dell Windows 7. I purchased refurbished computer from Dell but did not receive a users manual. How can I obtain one and can I find it in whole online? I also need software manuals...
support.dell.com/ - United States -
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=manual+photo+gallery
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=manual+photo+gallery#hl=en&expIds=17259,18167,24472,26637,27147,27404&xhr=t&q=manual+powerpoint&cp=13&pf=p&sclient=psy&aq=0&aqi=g1g-s1g3&aql=&oq=manual+powerp&gs_rfai=&pbx=1&fp=17af990832ea9b8f
Please find the links above to help you, the top link, is the Dell support, where you can find your exact make and model, and download your manual. Next, is a master Google link, for your manual for Photo Gallery, simply choose one you like and download it, this is the same for the next link, but this time it's for Powerpoint...If you need any others simply type in the name of the program and the words PDF manual download EG: MS Publisher PDF manual download (enter) Then, find one that has what you want, and download it to your desktop. You will also need Adobe reader installed to view the files.. usually though that's all installed, if not, download and install the latest Adobe Reader. it's free.
Nov 08, 2010 | Dell Computers & Internet
I have problem opening the photos from a friend in picassa
Hello
This problem can be resolved by opening the "Control panel" and selecting "All Profiles" under the "Color Management" file. Add the "sRGBIEC61966-2.1" profile to the "ICC Profiles."
Make sure that the digital photo file that you're trying to access isn't open or in use by another program on your computer. Oftentimes, two programs can't access the data contained within a file at the same time. If your photo is already open in another program, for example, you wouldn't be able to open it in your digital photo viewer/file manager.
Make sure that the file format of the digital file you're trying to open will actually work with the file manager you're trying to use. Not all programs are going to be able to open every file type. There are dozens of different photo files types in existence. Look at the photo file's extension and then look in the instruction manual that came with your file manager to determine if that program can read that particular type of file.
Reinstall your digital photo viewer file manager utility. If you purchased your program in a store, insert the CD-ROM you used to originally install it into your computer and select "Repair" when its setup program automatically opens. If you installed your digital photo viewer file manager utility from a computer file you obtained on the Internet, execute the original installation file and select "Repair" to reinstall your program on your computer.
Make sure you have the latest version of your digital photo viewer file manager. Programs are often updated by their original manufacturers to fix errors and issues that users have been known to have. Open your program and click on the "Help" tab. Look for an option that reads something like "Update" or "Check for Updates" and select it to connect to the Internet and make sure that you have the latest version of the program installed on your machine.
Nov 05, 2010 | Computers & Internet
I can open my external hard drive but not the pictures.
INSTALL ANY THIRD PARTY SOFTWARE THEY ARE ALOTT MORE FASTER , LIKE ACDSEE..GD LUCK
Jan 05, 2010 | Western Digital My Book Essential Edition...
Photo Gallery Can't Open Picture
Goto Your Official laptop site ,Download latest drivers for photo gallery ,install and restart ....I hope this helps you
harish
Feb 19, 2009 | Computers & Internet
I can't load new pics onto Windows Vista Photo Gallery anymore...
I finally figured it out. Somehow I had messed with the Autoplay settings uploading pics the last time I guess. Anyways, if you experience this problem, check this out first and see if it fixes it for you before you do anything else:
gl_arrow_down_static.gif What if the import dialog box doesn't appear? If the dialog box prompting you to import your pictures doesn't appear when you connect the camera to your computer, AutoPlay might be turned off. You can import your pictures using Windows Photo Gallery instead. Here's how:
1. Open Windows Photo Gallery by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking All Programs, and then clicking Windows Photo Gallery.
2. On the toolbar, click File, and then click Import from Camera or Scanner.
3. In the Import Pictures and Videos dialog box, choose your camera from the list of devices, and then click Import.
gl_alert_vert.png gl_icon_tip.png If you prefer, you can turn on AutoPlay or set AutoPlay to automatically import pictures from a digital camera. For more information, see Change AutoPlay Settings. gl_alert_vert.png gl_alert_bg_tip.png
Dec 22, 2008 | Acer Aspire 5050-3242 Notebook
I bought my computer from walmart in july of 07. doing that time i can receive pictures when i download them. when i receive a vedio and down load it, it download but,the vedio didn,t appear. a message...
The chat is not responding follow mmy instructions here.
Download one movie on the desktop.
Click right mouse button on the movie on the desktop and chhose the last command that is properties.
On properties box ther is a change button, click it and set it to internet explorer.
Nov 18, 2008 | Computers & Internet
HP Pavilion dv6000 driver not reading Sony Memory Stick Pro Duo
hey i have the same problem with the hp pavillion 6000. It is one of the most unreliable computers in the world but i guess thats another discussion... I have a 2g memory card that will only be recognized if i restart the computer and put it in then... Once you eject it though it wont recognize it. HP needs to get their **** together and stop ripping people off.
Oct 25, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
