Question about Dell Latitude D830 Notebook
Small "pop" noise similar to when the computer shuts down....but
Now there is ZERO...no power, computer will not start on battery or ac...dead in the water...nothing unusual about activity during occurence, just running word...
is it gone? if not, what are some of the possible problems/solutions/costs?
thanks...
  • hunterking Jun 07, 2010
    It could be a lot of things, but there is still hope for it. You need to tell me exactly what happened in simple terms. I only got it made a noise and quit. What was the noise? Was the laptop hot? Give me as much info as you can and I will try to solve the problem
  • 69 Answers
Does the battery light turn on when you plug in your ac adapter,,,one of the most common problems with this model is the power connect gets bumped when the ac is plugged in and breaks the conntector on the mb
Posted on Jul 10, 2010
How to remove keyboad on a laptop hp g61
The procedure is straignforward. For step by step intructions download the service manual from
http://h10032.www1.hp.com/ctg/Manual/c01868653.pdf
Please rate this solution. Let me know if you have any problems or questions. Thanks.
Jun 09, 2011 | Computers & Internet
Caps lock led not working
Sometimes electrical components needs to have all power sources removed and reintroduced to work properly. Try performing a hard reset first, if it doesn't work then try updating your BIOS. If neither works...It's pretty much dead and not worth fixing.
To Perform A Hard Reset
  • Shut down the computer by going to the Start menu and selecting shut down. (If you have no display, hold the power button down for 5 seconds)
  • Disconnect the AC Adapter from the notebook.
  • Remove the battery from the bottom of the notebook. There will be a switch/button to eject the battery.
  • Wait at least 1 minute with all power sources disconnected.
  • Re-insert the battery and reconnect the AC Adapter and then attempt to power on the computer.
May 22, 2011 | Computers & Internet
Computer will start to power up and then shut down.
Could be burn out power supply or dead battery before buy a new one borrow from a friend similar adapter with similar ratings
Mar 02, 2011 | HEWLETT-PACKARD nx9110 AC Adapter - ...
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
The clock on my laptop keeps setting to zero when I shut down. It seem to happen after a windows update. I'm running vista. Can anyone give me a solution. I have to keep putting the computer to sleep...
It sounds like your CMOS battery is dead. The CMOS battery keeps the date and time current as well as your BIOS settings when power has been turned off to the system. Check your system for the current type of battery your Toshiba uses. It either uses a disc type of battery that sits in a socket, or it has a disc type that is in a covering and attaches to the motherboard via a small cable.
Jul 12, 2010 | Toshiba Computers & Internet
Computer was on AC power. Left unattended it shut down. Would not wakeup. Shut down fully, it would not come back up. Get a 2 short beep code. Invites an F1 to go to setup. Won't go to setup. Screen then...
Can you tell if your AC power cord is working? (Is there a light on the computer that comes on when it's charging?) If the power pack went dead, your battery could've died and now you get no power to the PC which is why it won't boot up.
To test, take out the battery and plug the AC cord in and try to boot up. If nothing at all happens without the battery, then your power cord or power pack is dead, and you just need to replace it.
May 29, 2010 | IBM ThinkPad T21 Notebook
Dell inspiron+Blinking lights=dead battery?
Hello there:
yes laptop batteries do die over time depending on the use of them so i would first check and make sure that the power cord is working than if so than yes get a new battery.
and the battery should stay in the laptop to help keep the cmos battery on the motherboard charged ok?
hope that this is helpful for you
best regards mike
Jul 31, 2009 | Dell Computers & Internet
HP nx7300 no boot
I guess your battery needs to be flash.
Apr 10, 2009 | HP Compaq nx7300 Notebook
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Dell Latitude D830 Notebook Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
