Question about Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck
Tape slots won't open and nothing is functioning.
When turned on, the tape deck makes a whurring and it clicks and stops. It does this a few times and then nothing happens. The tapes wont eject, but the screen looks fine. They wont play or record almost like its locked...
    Champion:
  • 222 Answers
You need to replace your belts, go to partstore.com, punch in your model number and it will give you the correct belt's that you needed
Posted on Jun 08, 2010
How do I get a stuck cassette tape out of the Tascam 202 MKiii
With this kind of mechanism you need to open the deck up and assist the cam wheel by hand to get the eject block and heads to go down to the stop mode. This is the only way to get a tape out without destruction to both tape and machine. I have done it a few times. If you can not do it yourself, I am in the Chicago area as Skywave Tape Deck Repair. I can get the tape out.
Jul 02, 2015 | Tascam 202MKIII Dual Cassette Deck Studio...
The PLAY function of my Cassette desk doesn't work anymore
Well two things have to happen to make tape move in a cassette deck. One is the Capstan shaft has to rotate and that is usually a belt link to a motor through a pulley. The second thing is you must have take-up torque. If the tape moves but the take-up reel does not pull it onto the take-up reel then you either have a eaten tape or the deck will shut off. in your complaint it could be any of these items- maybe a bad Idler from the reel motor or the capstan belt is old and stretched.
Aug 10, 2012 | Kenwood Audio Players & Recorders
I put a tape in and it keeps flipping sides without playing and pops out and says Error. It even does it with a CD-Cassette Adapter. Before the Cln came up and I pressed on the eject button and that...
Cassette decks have sensors on the reels which tells the deck when the tape is at the end. When the reel stops the deck switches the direction of the tape and sometimes the position of the head(depending on the deck design). Most common problem is the tape is hard to turn, or the deck won't turn it ( deck thinks it's at the end, click, still won't turn, click, won't turn, click) you should fast forward and/or rewind your tapes from start to finish once in a while to keep them lined up(narrow spool/less friction), you shouldn't have to but it works. BUT,...your problem sounds like a slipping or broken belt/or dirt causing the problem. Take the deck out to have a look and clean the capstans(rubber rollers)belts,heads with alcohol and a Q-tip while your at it. Dirt's usually the main culprit and if you do have some other problem, cleaning it is always a win/win (It will also sound better clean)
Sep 20, 2011 | 1995 Buick Regal
Thaks for helping. My tape deck door has suddenly stopped working. the tape is inside and when i turn on the wpower there is a clicking sound. it is a TEAC AD-500 CD player/reverse cassete deck
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
Jul 14, 2011 | Teac R-H300 Dual Cassette Deck
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
Tape deck is stuck
push the eject button at the same time get a nail file and insert it in the tape slot
on the right hand side of the deck
it may take three hands one to push eject one to push the eject mechanism inside the radio behind the tape
and one to help remove the tape
if that doesnt work....dont try forcing anything as the stereo WILL break..... take the stereo out of the car, so it is not connected to the electrics, then either, gently take it apart with a screwdriver
I would suspect the belts, look for any small motors and missing belts. You may be able to manualy turn a wheel or gear till it ejects.
if your not comfortable doing this urself with the above said porcedures... its better to take it to the dealer...
regards iversh
A very helpful rating is appreciated for answering Your Query
Aug 30, 2009 | Panasonic RX-ED707 Boombox
Cassette Stuck in Sony Hi-Fi RV-888d
Actually when audiotape struck (Click-Click-Click), rewind and forward 2-3 times or manually rewind and forward 2-3 times with the help of pen. After you can play the cassette
I am also use the same music system (MHC – RV 888D)
Mar 21, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Tape deck won't open
If this is a deck where the tape slides in horizontally, like most car stereo tape players, you may have a broken or slipping belt. The fact that you "haven't used it in a long time" suggests a worn-out belt.
In my car stereo, the belt slips when it's cold and won't play or eject the tape. After a few minutes, the unit "warms up" and the belt starts turning. Then everything is fine.
I think we both need to replace our belts.
Nov 17, 2007 | Audio Players & Recorders
Clicking sound in tape deck
All Aiwas  are prone to this problem.  The doors are a real pain and easily give up the ghost.  I have 2, both probmatic in this direction.
I have spoken to others about this problem. Seems no easy fix.
Have you in your case, tried leaving and old tape in the tape part of your  unit . The noise you hear, usually starts when tape unit area doors are about to pack a wobbly. Unless under warrenty, proberly,
not worth getting fixed.    It seems something gets weak in the activation part and get a mind of its own.  Very common after about 3 yrs of ownership.  All the best: jamz
Apr 05, 2007 | Aiwa NSX-AJ20 CD Shelf System
Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck Logo
435 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
