Question about Saeco Talea Giro Espresso Machine
Hi , I have a Saeco Taleo coffee machine and have problems with brewing. The coffee get ground and then the brewing fails . Anu tips on what I need to look for ? Thanks Christina
  • christina467 Jun 07, 2010
    I am not accepting the advise from your "expert" there are no screws to take the casing off - they are stecially sealed screws - and why not start with a simple method - I am no electrician who can fix and replace wires - what a waste of money
    President:
  • 1,961 Answers
Hello!check weather the heating element is properly connected to the power supply AC source.to check it you need to open the electrical wirings of your coffee maker.the wiring arrange like this.From the AC cord with line 1 and line 2 the line 1 goes directly to the heating element terminal 1 and the line 2 run to the power switch then to the terminal 2 of the heating element.check its continuity if wirings are intact,then the heating element needs to be replace...tnx
hope this helps you...
please rate my help..god bless!
Posted on Jun 07, 2010
    Dear Aplug -
    you have me baffled- what has the heating element to do with a blocked brewing run?
    the heating works perfectl as I can heat up milk to boiling point -
    I would really like a refund - a sI feel that both of you are giving me a "run around" on a problem you have no idea about -
    President:
  • 1,561 Answers
Follow the below procedure to troubleshoot your Saeco Taleo coffee machine.
You go with the visual check first. Check on the electric cords, switches, timers, fuses, thermostats and heating elements to see if there are any damages components.
If there are some damages that are visible visually, get it replaced or repair it, if not, then you would have to dissemble the coffee maker to assess the thermal fuse.
Unplug the unit from the electrical receptacle.
Remove the carafe and filter basket. Also remove the water reservoir lid
Turn the coffee maker over and remove the screws that secure the case. Remove the case.
Take a look at the control cavity and assess. If it is a a case of disconnected wire, debris etc. simple fix, reassemble and test. If it is not so, continue to the step 7.
Use a multi-meter to test the warming and heating elements, the switch, thermostats and timer.
For any parts that is defective, work out the costing and if it worth the while, replace it.
Reassemble the appliance and reinstall the carafe and basket.
Top up the water reservoir to 50%, then test it by turning on the coffee maker.
The problem should be solve with the above troubleshooting.
Take care.
Posted on Jun 06, 2010
I have a saeco super automatica Leaking water
Take the brew unit out when the machine is off and cold. With your finger, check the well next to the large gear on the inside of the machine. This is the gear that fits in the back of the brew unit when it is in place. That well may be clogged with fine coffee grounds and some mildew build up. You might notice that after brewing, very little water will has been flowing into the drip tray. Take a Q-tip and push it through the hole at the bottom of the well to remove the coffee ground buildup. The excess water after brewing will flow through normally now and not behind the brew unit.
Mar 02, 2017 | Saeco Coffee Makers & Espresso Machines
I have a taleo touch, it worked perfectly for the first 40 brews but now as soon asw i turn it on it starts brewing a double long coffee without me pushing anything!! once it is finished, it doesnt allow...
This sounds like a new unit. Phillips suggests returning it to local store for replacement.
Link to Phillips/Saeco website
Phillips Customer Care Number: 1-888-744-5477
Monday - Saturday 9:00 AM - 9:00 PM EST Sunday 9:00 AM - 6:00 PM EST Excluding Major Holidays
May 02, 2011 | Saeco Talea Touch 14-Cup Coffee Maker
I have a Saeco Magic De Luxe. I am having a problem intermittent
Could be the pump not providing enough pressure to force the water through the coffee. When using beans or preground, can you still hear the pump function?
Jun 30, 2009 | Saeco Magic De Luxe Espresso Machine
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Unable to get White Saeco Cuppacinno Machine to work.
Hi
I would say that your brew unit is not locked in.
Brew group missing indicator
Open the door on the right. Push on the upper left side of the brew unit until you hear a click. Close the door and see if the message is gone. If it is make sure that the grounds drawer is in place.
Tip: Pull the grounds drawer out, then push it back with only 1 finger and push it on the right side of the drawer. This will make sure that it engages the micro switch.
May 04, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Oct 13, 2008 | Saeco Royal Digital Plus Coffee...
Saece Talea - Dispensing failed
Take out the brewing unit and clean it in hot water.
/Mirran
Aug 30, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saecco Taleo Touch Espresso Machine
Make sure you preheat the cups, as that can make the world of diffrence.
if that dont help send it in to a offical Saeco repair station for upgrading of the software, or change of termostat or boiler.
May 27, 2008 | Saeco Coffee Makers & Espresso Machines
Water in the coffee grounds drawer
Look for a leak near the brew group on near the piston area.
Changing the brew group should solve this problem.
http://cerinicoffee.com/item.asp?cID=0&PID=206
Johnny C
www.cerinicoffee.om
Oct 01, 2007 | Starbucks Saeco Italia Digital Barista...
Saeco Talea Giro Espresso Machine Logo
453 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
