Question about Yamaha HTR-6130 Receiver
SAID CHECK UR SP CABLE? - Yamaha HTR-6130 Receiver
    Brigadier General:
  • 8,546 Answers
Don't you mean it said, "Check SP wires"?
And what was the result when you did that?
How about if you disconnect all the speakers and try again. Then what? Add one at a time until it either fails again or starts working with all speakers attached.
Still fails with all speakers disconnected? Take it in to a shop.
Posted on Jun 07, 2010
My yamaha receiver RX-V363 keeps shutting off and saying check SP cable
It is one ot two things, the audio output transistors or ic,s are shorted, or the speaker wires in the back of the surround sound are shorting.
Apr 08, 2012 | Yamaha RX-V363 Receiver
Quasar VV-1301 cant program for cable tv channels without remote, is there a way to autosearch the cable for channels so they are able to be selected
Ur tv have a manual Menu button on the front of the tv bazel frame?Yes used that manually Menu button pushes go into the tv menu to find select CABLE do autosearches by hand through a manually selected by functions buttons like channels buttons up and down as selections and menu button as enter to excicute functions.No try website like Remotes.com to buy the tv original remote to used.
Aug 18, 2011 | Quasar SP-3235 32" TV
Just hooked my Samsung SP-S4243 up do hdmi cable but it won't display full screen.
Sounds like the cable box is outputting in 4:3 rather than 16:9, it should also output in either 720p or 1080i/1080p. Check the settings on your cable box and set them to 16:9 and 1080i/180p. If that does not rectify the problem then you need to look at the settings on your Samsung
Jan 03, 2011 | Samsung SP-S4243 Television
I use WINDOWS XP SP 2...mainboard MSI N1996,
It is fault in Ur Windows firstly repair Ur windows then install driver but recommended restore backup must.
Feb 15, 2010 | Computers & Internet
Code shows SC 548 how do I clear this
SC548: Fusing unit installation error - Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed
· Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion,
this sc 548 usually happens when paper jam occurs and user does not properly fit the fuser... also not fiitted properly due to some foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
Aug 09, 2009 | Ricoh Aficio CL3500N Laser Printer
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
i think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
Apr 23, 2009 | Yamaha RX-V757 Receiver
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Feb 03, 2008 | Yamaha HTR-6030 Receiver
INFOCUS LP580 will start but no lightcomes up temp light is not showing any activity after start up
what I understand is that your lamp is not giving light. Pls check the ballast unit for that. Or tell something more about ur projector to solve the problem.
Jan 25, 2008 | InFocus SP-LAMP-LP5 Projector Lamp for...
Yamaha HTR-6130 Receiver Logo
125 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
