Question about Jandy Laars Lite2 Ld 400,000 Btu Heater
I have a volt meter and would like to use it to test some connections to figure out the heater does not light. Can you tell me where to place the leads?
    Scholar:
  • 78 Answers
First start at the line voltage coming into the unit. The LD model is supplied power from an external source. Once line (supply) voltage is checked, start at the transformer and trace all the circuitry. Meter set at 50 VAC should do it. The supply voltage will supply 120 VAC to the igniter. Here is a link to the PDF manual fro Laars/Jandy/Waterpik Lite2 heater
Posted on Jun 07, 2010
Where is resistor for heater blower motor on infinity g20 2002
The resistor is an in-line resistor. You will have to follow the wire back and find the resistor and replace it.
Dec 31, 2014 | Motorcycles
Ok here goes, I'm not mechanically minded so please bear with me. I think I may have broke the connection cords that connect to the battery terminals while trying to put in a new battery as that's what I...
Use a volt meter or 12 volt test light to test for current at different places. Start with the battery terminals, then leave the one test lead on the negative terminal and test for volts further away from the battery,(on positive side of circuit) like the big bolt connection i see in the pic. then test in the fuse box for volts. This will tell you where the bad connection is..
Dec 21, 2014 | Cars & Trucks
The battery is good..how can i tell if its the alternator
Most auto parts stores offer testing for free. A volt meter can also be used to check alternator output. Connect the meter leads to the battery. The voltage should be at least 12 volts. If it isn't, then find out why. Just because a battery is new does not mean it is fully charged. If the battery voltage is OK, then start the engine and observe the meter. It should now read approx. 13.5-14.5 volts. If it does, then the alternator is charging. If it isn't, then the alternator should be tested. While your at it, you might as well check your belt tensioner for proper operation.
1. leave the engine running and the meter connected.
2. Turn on your lights and other accessories. (heater, radio, high beams)
3. Observe the meter reading.
The voltage should remain between 13.5-14.5 volts. If it doesn't, then determine the cause and repair as needed. If it does, then the tensioner and belt are probably OK. I hope this information is helpful to you and thanks for using FixYa.
Jul 29, 2011 | 2006 Chevrolet Cobalt
Cig socket has no power fuses are ok
Use a volt meter or a test light to test voltage. Connect negative lead of meter of test light to ground and connect the positive lead to the center of cig socket. I no voltage is detected at cig socket trace wire to fuse panel and connect postive lead of test light or volt meter to positive side wiring at fuse panel.
Feb 24, 2011 | Mitsubishi Outlander Cars & Trucks
No power, backfiring thru the carborator. need to know what the problem is
Hello! lets check the Manifold Absolute Pressure (MAP) and the Throttle Positioning Sensor (TPS) in that order...if you have a multimeter and a wee bit of experience using one both of these sensors can be tested...If not replace the MAP first and the TPS second...
The MAP has a three wire connector with wire colors Orange/White...Blue/Light Green...And Black./White...using two safety pins push one into the rear of the in-place connector into the Blue/Light Green...The other into the Black/White...connect the + probe of the meter set to read 5 volts on to the Blue/Light Green pin...the - probe to the Black/White pin...turn key to on...Meter must read at least 3 volts...If not MAP is defective...
Using the same technique lets test the TPS...Three wire connector Green/Light Green...Orange/White and Black/White...Safety pins into Green/Light Green and Blue/White...Set meter to read 5 volts...Place + probe of meter on Green/Light Green pin...And - probe on Black/White...start the engine...at idle meter must read less than 1 volt (.85)...slowly increase the idle (as best you can)...Meter should rise smoothly to 4 volts...If it skips, jumps or acts erratic the TPS is defective...See pictures below...Guru...saailer
saailer_28.jpgMAP
saailer_29.jpgTPS
Dec 07, 2010 | 1984 Ford F 350
I hit the brake and the lights dim changed the brake light switch sill the same disconnect the brake light switch and it does not traced the wire as Much as I could see do not see any bare spots. need...
You didn't say what year or model your bike is but if you had a dead short somewhere, I'd think it would blow a fuse or you'd have a light that will not work. Since you said that the lights just dimmed, you may have a charging system problem.
For a preliminary test, let's check the output of the system. You'll need a DVOM (Digital Volt Ohm Meter). The battery in your bike must be fully charged and all cables clean and tight. Connect the meter across the battery by connecting the red meter lead to the positive post and the black meter lead to the negative post of the battery. Put the meter's function switch in DC VOLTS, 20 VOLTS or higher range. Start the engine and bring it up to a high idle of about 2000 RPM or more. You should read 14.5-15.0 volts across the battery. If you read less than this, allow the engine to run for another minute or so and check it again. If it doesn't come up to the correct voltage, you charging system is not functioning properly. You may have a bad stator or regulator.
Please repost and tell me the model of your bike and I'll tell you how to test the alternator output.
Good Luck
Steve
Nov 27, 2010 | Harley Davidson FLHTC - FLHTCI Electra...
Fan on my big buddy heater just stopped working changed batteries still not working?tried the switch nothing .i only have radiant heat.
I would first check the wiring connections to fan and get a multi meter , set on 12 volts dc and see if fan motor has 12 vdc input voltage.
Too cheap to buy a voltage tester at wal mart ot harbor frieght, you can use a 12 volt bulb and socket, if you already have one. Remove fan wires & hook up 12 volt light bulb & if it lights, you got the juice. Carefull,dont let live wires touch because you short out $26.00 big buddy fan transformer. work with fan transformer unplugged from wall and dont plug in until you sure no wires touch.
use electrical or duct tape. electrical tape better.
otherwise,just buy the multi meter, they only $8.00 to $10.00
read & understand instructions, before you try to use it. otherwise,you could burn out your new meter.
well worth owning &
learning to use multi meter. I use it thousands of times.
if fan motor has juice but wont run, check fan shaft to see if it turns freely or scrapes or is stuck. oil fan motor bearings ,change the brushes.
make sure that the fan blades are not touching the fan housing and can turn freely.
if it still dont work, buy new fan motor.
if no juice at fan motor, check mr heater switch with the power off,unplug transformer from the wall or remove batteries.,
and use the ohm meter setting of the multi- meter to test for continuity of the switch when the switch is in the on position.
power must be off when using the ohm setting of a multimeter.
if power is on & using the ohm setting of the multi meter, you will blow out the multimeter. The ohm setting uses a 1.5 volt dc battery inside the multimeter to test for a compleated circuit.
so, 12volts dc would blow it out on ohms setting.
TESTING FOR OUTPUT OF FAN TRANSFORMER OR BATERY PACK.
If the switch is good,reinstall it on mr.heater and test the output of the transformer or battery compartment using the 20 volt dc scale of the multi meter. the voltage scale you select ,must be higher than the voltage you expect to find ,in order to avoid damage to the multi meter.
observe polarity,positive to red and negative to black.
the dc voltmeter setting is totally polarity sensitive and a reversed hook up could blow out the meter.
multi meter means it can read ac volts, dc volts,ohms and dc amps. Read and understand the included instructions before using a multi meter
a good single battery in new condition reads 1.62volts dc
1.5 vdc is almost dead, a good used battery reads 1.58 to 1.6 vdc
below 1.58 vdc is weak battery and 1.48 vdc is usually totally dead, but may be enough for momentary usage under 1 minute.
Sep 08, 2010 | Mr. Heater Big Buddy Heater
How do you know if it is the element that is bad or the therm-o-
Disconnect the electric for the unit. Disconnect the two wires from the two eliments. Place a battery type test light or Ohm meter is more conclusive if you have one, Light should light when placing the two test leads to the two eliment contacts(while they are disconnect for the water heater wiring) should be dim but glowing. If no light the the eliment is open. If an Ohm meter the Wattage is written on the heater the heater. E=IR P=IE. It should work out to about 1200 -1400 ohms if 220 volt heater. If the light is bright just as if you had put the two test leads together,then you can say that the eliment is likely shorted. Either no light or a Very bright light requires the eliment to be changed.   To check the thermostats, Raise the ajustment one one at a time, until it clicks. Listen for the heater to be heating. Turn that one back down and do the other one the same way. I hope I have been clear enough. About one gallon of water should be drained for the bottom of the tank once a year along with checking the preasure/tempature safety relief valve by  operating it ,using the leaver,for  a few moments as preventive maintenance.
Feb 11, 2009 | Element Chromalox SG1353-430326 Electric...
Have a 2002 Kia Sportage . We had to replace the starter. But our windows Quit working and the heater quit working. Can you tell me what is wrong? And can you tell me where the fuses to the heater and...
One may or may not have anything to do with the other. I would check to see if the main battery connection on the starter has additional wires on it, making sure they are all connected and not broken. (sometimes this terminal is used as a junction point for other electrical components.) There has to be a fuse pannel in the car... sometimes two.(owners manual will show location(s) I don't work on these vehicles, but once fuses are located, I generally test each while they are connected, with a test light or volt meter. With key on, every fuse should have power at both sides (except headlamp fuse)
Jan 03, 2009 | Kia Sportage Cars & Trucks
Worn out baseboard electric heaters
The only safe way is to read the voltage with a AC voltmeter. Turning off the power to that heater connecting the test leads and turning the power back on. There is only two leads going to the heater and you should always dissconect the power befor connecting the test keads. Your meter shoud be set to read the highest of the two voltages.110 Volts or 220 Volts. You might get lucky and find a name plate on the unit with the voltage shown.
Feb 22, 2008 | Heating & Cooling
Jandy Laars Lite2 Ld 400,000 Btu Heater Logo
229 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
