Question about Frigidaire Heating & Cooling
My d has a 25,000 btu frigadaire AC. The compressor comes on for a few minutes and then goes off it won't stay on . Can you tell me what might be wrong?
  • 674 Answers
It may need to have the refrigerant charge checked. If you have a schematic for it check and see if it has a low pressure switch. This will stop the compressor to protect it from overheating.
Posted on Jun 07, 2010
Compressor keeps turning off and on. Stays on for about a minute. Cycles off. Then stays off. Does recycle after a few minutes. How do I add coolant and where.
It is normal for the compressor to cycle - when a certain pressure is reached in the system, a pressure switch disengages the compressor clutch, and then activates it again when then the pressure drops below a certain point. Unless your air temperature doesn't stay relatively constant, there is no need to do anything. If it doesn't, the system may need recharging and that should only be done at a certified repair shop.
Jul 06, 2017 | AC Cars & Trucks
Desa Natural Gas Wall heater 18,000 BTU
Hi i think you a right on the money with the pipe.
It could just be that their is a build up of dust causing the problem as this can happen if the unit hasnt been used often let me know how often its used and also the age thanks
Dec 14, 2007 | Tower Desa Natural Gas Heater - 25,000 BTU
My frigidaire AC starts cooling fine but stops blowing cold air after few minutes and it does not cool at all. I haved turned it off and re-started it and it does the same thing
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Aug 17, 2016 | Frigidaire FAS256R2A 25,000 BTU Window Air...
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Window air conditioner cools (very icy cool air) for a minute or two then switches to fan. Will then stay on fan for about 10 minutes and then once again get "very cold", but only for a minute or two
Before I even read that far into your post, I was thinking "thermostat" replace it...It seems to be failing badly. If you take it into logical perspective...normally the unit gets turned on, then takes a bit to get cold, then once it reaches its pre-determined temperature, turns the unit either "off" or just blows the fan...by kicking off the compressor. This unit you have is getting this cycle done within 5 minutes instead of a few hours...replace the thermo and you should be fine. Now if you could post the exact model number here I can go look up the part for you.
Jun 20, 2012 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
Ticking noise in the dash when I turn the car on or off.
could be you a/c compressor, you may need to have the pressure checked
Jun 07, 2012 | 2007 Hyundai Entourage GLS
Compressor doesn't stay on?
It could be anything, even cleaning the grill and change or clean the air filter might help. Does it get cool or does it warm up? The most likely problem is the starter capacitor and they are easy to install and cheep too. Let me know if you want the site to buy them at, if you have a test meter let me know and I can tell you how to test it before you buy parts. And thanks for using Fix-ya and please rate this free question if it helped, and get back to me if you need more help
Avid101
Aug 20, 2009 | Heating & Cooling
AC Compressor goes off past position 1 on the fan dial
Sounds like your carge is adiquate. The climate control center seems to be at fault.
Jul 25, 2009 | 2004 Nissan XTerra
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Heating & Cooling Logo
    73 people viewed this question
    Top Frigidaire Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
