Question about Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582
My 10amp fuse keeps blowing after the generator has only been running for less than a minute. This fuse is located on the back of the box with the idle control button. This fuse is what starts and keeps the engine running.
2 Suggested Answers
protek480
  • 1714 Answers
SOURCE: Fuse blows repeatedly
The auto speed control is failed. Keep it manual and see how it does...It will run at full throttle even when no load is running. Then fix the throttle control when able.
Posted on Aug 09, 2009
Why does the 10amp fuse keep blowing
Something is shorted out somewhere. Have you tried disconnecting any devices plugged into the unit and then seeing if it still blows the fuse?
Jul 03, 2014 | Pentair P 100 Intelichlor Power Center Kit...
2002 pt cruiser fuse #11 blown
According to my diagram, number 11 is a 10amp fuse that powers the ac clutch relay. I don't see how it would keep the engine from starting.
Is the fuse you are talking about in the engine compartment box and is it a 10amp ?
Aug 06, 2012 | 2003 Chrysler PT Cruiser
2003 nissan pathfinder blows tail lamp fuse
you got a wiring issue that keeps shorting out fuses find that and that should take care of everything else
Mar 08, 2012 | Nissan Pathfinder Cars & Trucks
Keeps blowing starter fuse when you turn the key to start engine.
YOU GOT A IGNITION WIRE TO STARTER SHORTING TO GROUND.
May 06, 2010 | 2000 Toyota Camry Solara
Need a diagram of the fuse box for a 1994 volk
Heres a picture of fusebox,and listed is the fuse locations,1) 10amp left low beam light
2)10amp rt low beam light
3)10 amp instrument& license plate light
4)15 amp, rear wiper
5)15amp frt washers and wipers
6)20amp A/C fresh air fan.
7)10amp rt tail & side marker lights
8)10amp left tail & side marker lights
9)20amp rear defroster &heated mirrors
10)15amp fog lamps.
11)10amp left high beam
12)10amp rt high beam
13)10amp horn, rad fan run on
14)15amp backup lights (m/t),power mirrors,heated seats,heated washer jets,cruise control (m/t)
15)10amp engine electronics,coolant pump run on(v6)
16)hazard signals,glove box lite,shift lite
17)10amp turn signals
18)20amp fuel pump, oxygen sensor
19)30amp a/c, rad cooling fan.
20)10amp brake lights,cruise control.
21)15amp dome light,cigar lighter,locking system,multifuntion indicator,clock,vanity mirror.a94b062.gif
Mar 10, 2010 | 2003 Volkswagen Passat
My c15 citreon van keeps blowing 10amp fuses for side lights etc since fitting a new radio, i have taken the radio back out but it is still doing it, can someone please help? It seems it is ok when vehicle...
please check your total circuit related or connected with 10Amp. fuse, anyhow i think it is semi short circuited. u have to find out where the short circuit occurred. to find out the problem u can start checking from side light holder...........
thanks
Oct 06, 2009 | Car Audio & Video
2002 kia rio keeps on blowing out 10amp fuse. when running. I think it's the 10amp computer fuse?
SOUNDS LIKE A SHORT COULD BE ANYWHER FROM ECM TO WIRING I WOULD TAKE IT TO A SHOP FOR 1-2 HR LABOR THEY CAN LOCATE THE PROBLEM ? MOST COMMON ARE WIRES RUBBED INTO IN HARNESS HIGH STRESS AREAS NEAR ENGINE, LOOK FOR WIRES TOUCHUNG OR FRAYED INSULATION ON THE WIRES GOOD LUCK
Aug 24, 2009 | 2002 Kia Rio
I have a 1998 chevy blazer (s-10) 4.3L 4x4 it keeps blowing the #15 (10amp) 4wd fuse, if you put a 10 amp fuse in it will blow the minute you turn it on ,then we put a 15 amp in it seems to do it when you...
check transfer case electrical switch, sometime if it bad it will also blow the fuse. don't recommend you put any higher fuse than recommend, If the fuse blow there is a short some where and by putting higher amp fuse you might short or burn something else beside the fuse. if that check out than check your transfer case motor, might lock up and not allowing the motor to turn instead it short the fuse. don't drive the car, just leave it in park, put correct fuse amp back in and unplug transfer case electric switch and turn the key on (dont start the car) and see if the fuse blow; if not plug it back in and see if it blow the fuse. if that is not the case, unplug transfer case wire, and do the same and see if it blow the fuse.
Jul 12, 2009 | Chevrolet Blazer Cars & Trucks
Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582 Logo
339 people viewed this question
Top Generac Guardian Electrical Supplies Experts
jdthefixer
ken skalski
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
