Question about Jack Lalanne Power Juicer 250 Watts
My Jack LaLanne powerer juicer elite will not turn 'on.' I believe all is set up correctly. The veggies are piles high - all cleaned etc. Did not use this machine for about one year. It's been quietly resting on my kitchen counter. Have no idea what could be the problem. Kara
  • 20 more comments
  • farfalla_kar Jun 06, 2010
    The Juicer has been taken care of well during the time (6 mos to one year) that it was not in use. It has been safely and beautifully kept on the kitchen counter. Is there any other idea about getting this to turn on?
    The machines are now priced quite low, and in New York City, to have a technician 'come' would be quite pricey, I'm sure. Why would the machine not work simply because it was standing for a period of time?
    Thank you,
    Kara
    The FixYa person was able to help me to start the machine by telling me that there were at least two safety fittings on the machine. The blue bucket needs to be fitted tightly at the base and the metal closing over the top must be snapped into place tightly.
    It was the blue bucket with a little plastic point that had to slide in at the base into the main part of the juicer! As soon as I was able to survey this area and try to make all flush, the machine worked perfectly. How does that machine sense that the little plastic point was not fitted into the plastic base frame? Quite amazing.
    I LOVE this machine!
    Fine, gbooze. Will accept the Solution, but have not been on the page to do so. Something came up asking me to comment re. the machine.
    Kara
    I am happy to rate the solution - Top Notch!!! but cannot seem to get to the page.
    I'm rating gBooze's solutions: A1!!!!
    Thank you.
    Kara
  • Anonymous Mar 11, 2014
    Disc will not eject from stereo system in Kia rio 2006CVVT
    CAN U TELL ME HOW TO DOWNLOAD WATSAPP TO MY GT-S5233A PLS?
    I m using bb 8520 curve how can I download auto call recorder in this device
    need a new windshield washer sprayer for a 1997 acura cl 2.2
    coffee select button is stuck indented
    I have my printer wired to fax but I want to bypass the fax as I think it's causing the drops. How do I rewire to bypass the fax? If I need the fax I will reconnect at that time. Thanks!
    crisper drawer in kitchenaid refrigerators
    Determine resale value excellent condition.
    The metal end connection of the charger to the scooter gets very hot while charging
    : The Vivitar Experience Image Manager vivi cam x028
    torque pattern 99 plymouth breeze 2.0
    01 vw passat won't restart after it stalls out at a red light or when in idle. It cranks over strongly until you run the battery down. it has a slight hiccup that will kick the cruise control off. It has been a problem ever since I had the timing belt replaced, water pump and oil lifter rod ( which was the original problem ) I had the timing belt and waterpump replaced because of the mileage.
  • Anonymous Mar 12, 2014
    charter remote control code for sylvania ld320ssx
    The TV loose the picture and the sound after been on for 30 second and them goes back again fine for another 30 seconds and them goes on and off over and over.
    lost clasp to watch - need a new clasp for skagen watch
    my mazda rx8 wont start and on my dashboard is a flashing symbol of a car and a key on it. what does that mean?
    constant squeak at left front wheel
  • 713 Answers
Hi,The blue collector bucket has a cut off switch at the bottom. Make sure it is snapped in place. The stainless bar that runs across the top also has a cut off safety switch. Make sure it too is snapped in place.better still,you might have to check the power outlet,this might also be responsible for the problem,
perharps,since it has been used in a long period,the juicer might need a general cleaning and servicing to restore it back to normal working condition.
Thanks and take care
Posted on Jun 06, 2010
  • 1 more comment
    Dear gbooze,
    Thank you so much - the blue bucket - the fitting point was not totally in at the base, and that stopped the motor from working. How sensitive.
    Again, many thanks. So happy I didn't have to get a service person in, since in NYC, this could be pricey!
    Great help - You saved us!
    All the best,
    Kara
  • Oyelade Gbenga Jun 06, 2010
    So glad i solved your problem,but you have to accept my solution,that's the only way i understand you appreciate my service.
    Thanks and have a nice day
    please you have to rate my solution,to show that i was really very helpful to you
    Thanks for your co-operation
  • 1,284 Answers
Hi, since you claim not to have used the device for about a year and it worked the last time you used it before dumping it somewhere then all you need to do is call in a tech to do a general cleaning and servicing of the powerer juicer. Once you leave an electronic device for a long time, it usually does not respond when you try using it again and all you need do it service it and it will start working...
Take care
  • 2 more comments
    Dear Sheikhtijani,
    Please forgive me, but I take exception to your phrase 'that it worked the last time I used it before DUMPING IT somewhere." I wrote the question several times so I don't know which you saw, however, it has been resting safely and beautifully on my kitchen counter since I used it.
  • Shehu Pro
    Shehu Pro Jun 06, 2010
    Hi, am really sorry about the mis-use of the word, i tender my unreserved apologies..
    Thank you.
    Kara
  • Shehu Pro
    Yes sir/ma, you can now accept the solution...
I have a Jack La Lanne juicer and cannot take it apart
There is a step-by-step video on Youtube - this should help ...
This link should get you there, or just Google Jack LaLanne Juicer and you should see a couple of youtube links.
www.youtube.com/watch?v=fDJkOPt5SPk
Jack LaLanne Power Juicer Elite Cleaning
Jun 14, 2015 | Jack Lalanne Power Juicer 250 Watts
I need apulp catcher for jack lalanne elite. it will not start because a small piece of plastic has snapped off
Available parts for the Jack LaLanne Power Juicers can be found here:
https://www.unitycart.com/pjss/parts/parts_classic.asp
You might take time to browse the site, you will find How To videos, manuals, Tips and recipes.
Mar 31, 2011 | Jack Lalanne Power Juicer (Stainless...
Was given Jack Lalanne power juicer elite model MT-1066 for Christmas just opened it now & there is no manual. It is in it's lock position & there is no power at all.Can you help me ??????
The Operating Manual for the Power Juicer Elite is available here:
http://www.powerjuicer.com/pdf/elite.pdf
Check to make sure machine, including pulp collector is properly assembled; check silver bar is in upright position; check that spout is in downward position; preset reset switch located on underside of the main base.
For Tips and to view How To videos visit the website at:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
Mar 19, 2011 | Jack Lalanne Power Juicer (Stainless...
Instruction for jack lalanne elte
Manuals for the Jack LaLanne Power Juicers can be found here:
http://www.powerjuicer.com/power-juicer-manuals.php
You might take time to browse the site, you will find How To videos, Tips and recipes.
Oct 31, 2010 | Salton JM411 Juiceman II Elite Juicer
How do you take apart a jack lalanne juicer to clean it
Suggest you review the series of How To videos on the Jack LaLanne website:
You will also be able to find your Operating Manual which contains illustrated Assembly and Disassembly Instructions
Jun 22, 2010 | Jack Lalanne Power Juicer 250 Watts
Jack LaLanne Juicer
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Dec 07, 2008 | Jack Lalanne Power Juicer 250 Watts
Stop running in the middle of juicing
well this is very common with this version, clean inside out, shredded fruits and veggies tend to stick and jam blades.
Jan 09, 2008 | Jack Lalanne Power Juicer (Stainless...
Need Power Juicer manual
Found online. They don't make finding the manual easy. Try this http://www.powerjuicer.com/pdf/classic.pdf
Nov 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
191 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
dflynn2204
Level 1 Expert
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
