Question about Maytag MER6772 Gemini Electric Kitchen Range
How does self clean oven work
Do not know how to do self clean oven cycle. can't find manual
  • Maytag Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Jun 07, 2010
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
Can I use the stovetop when my oven is self cleaning?
Yes you should be able to but there are a couple things to consider. When the oven is in the self-cleaning cycle the heating element reaches a very high tempature and runs for extended periods. So if you have a couple top burners going the amperage draw could possibly trip the electrical breaker. Also there is a lot of heat generated around the range during the cleaning cycle and it may be to hot to actually work around the range. There are some ranges that dis-able the top burners during the self-clean cycle. If that is the case with your range then the answer would be no. The way you would know for sure is to try them during the self-cleaning cycle or consult your owners manual.
Apr 10, 2010 | Maytag MER5770 Electric Kitchen Range
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I don't know how to clean the oven
You should have a function switch that says " self clean ". Normally, all you have to do is turn the control on to "self clean" and let the oven do the rest. It will take about 3 hours or so to complete the cycle.
Jan 30, 2009 | Dacor ECS127 Epicure Electric Single Oven
GE Medallion 850 oven self-clean instructions
how do i work the oven section i don't understand the settings
Oct 26, 2008 | Kitchen Ranges
Crosley self cleaning oven manual
I have a crosley but don't know if it is the same model.
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps! RC
Jun 21, 2008 | Crosley CE35111AA Electric Kitchen Range
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
345 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
