I have my hoover nextra washing machine on the 40 non fast wash but when it gets to draining out it stops... and also when I did a spin it didn't drain away either. my husband can't find a prob with drainage...
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (refer to manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum). Snaking out your standpipe would be good too.
Pl. rate if helped.
Posted on Apr 10, 2008
Wont drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 14, 2011 | Hoover Nextra HNF 3157 Front Load Washer
Hoover washing machine model HNF71683D not draining water
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Feb 28, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
Feb 02, 2010 | Hoover Nextra HNWL 3126 Front Load Washer...
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Hoover nextra 1200
The machine only allows a limited time for all the water to drain out before it starts spinning. If the is a blockage or obstruction in the drain hose or drain pump, the machine will not allow all the water to be pumped out and it will not spin. Check for any restriction especially under the sink/tub where the drain hose attatches to the drain spigot.
Nov 01, 2007 | Washing Machines
Draining & Spinning
I had a problem and when they took the back off. Underwire bra had got jammed through drum holes which stopped it spinning and water issues. I hope this might help.
Dec 17, 2006 | Hoover Nextra HNF 2137 Front Load Washer
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
