Question about Garden
PTO clutch gone bad.
I recently acquired a snapper LT16 lawn tractor. the electric pto clutch is seized up on it and i need to rebuild/replace it. However, a brand new one costs at least $150. I'm trying to find some used ones on ebay and craigslist, however ones for my particular tractor are scarce. I can find a whole bunch of ones that seem to have the same dimensions, however they're for JD's or other brands. So, i guess my question is; do i have to find one that originally came off of a similar tractor, or can i just get one that has the same dimensions. Thanks.
5 Suggested Answers
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
  • 394 Answers
SOURCE: DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Posted on Apr 30, 2010
Testimonial: "Hit on the head with such a simple solution"
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
  • 171 Answers
SOURCE: Cub Cadet 1650 PTO Issue, I think?? I have an
I'm wondering if your battery is going bad or if it does not have enough capacity for the cold weather.
Do you have the headlights on? Does it last longer without loading down with them turned off? If you turn them on does it start to load up faster?
The alternator on these tractors are generally large enough for normal applications and keeps the battery charged, but factors like cold weather and heavy loads, they can't keep up.
If you battery is getting older and won't hold a charge well this may be the real cause.
If you decide this is the problem, buy the battery with the biggest capacity that will fit.
Posted on Jan 13, 2011
What are the two wires on the PTO for?
John, the wires put power to the PTO to energize clutch and make it engage when switched on. I will post a video link of simple fix for wire that have been ripped out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Repair Ripped Out Wires On An Electrical PTO Blade Clutch
lawn tractor pto wire Google Search
Troubleshoot Replace mower PTO CLUTCH
Broken PTO clutch wire JD717A
Apr 22, 2016 | Garden
I have an LT series Snapper rider with 20 hp and 44" cut. The transmission seems to be slipping. I have not checked the oil. Replacing the belt looks like a big job.
Not as some John Deere mowers I worked on lately.
I am assuming your is the Hydro version with electric pto. First set the parking brake as this remove tension on the belt.
You will need to remove the pto clutch and attention to the keys are positioned as they are one way keys. When reinstalling the PTO clutch it torqued to 55 ft lbs. To do this you need to remove the engine shroud so can block the flywheel movement.
The rest of the belt removal and replacement is fairly straight forward.
May 06, 2015 | Snapper Garden
I have a cub cadet 2542 shaft driven lawn tractor. The PTO will not engage the blades what could be wrong?
bad relay or bad pto clutch to check clutch jump from battery to clutch electrical connector at clutch see if clutch engages if it does bad relay or bad switch if it doesnt bad clutch
Jul 22, 2014 | Garden
What could cause a pto clutch to seize and a idler pulley to got out?
First thing is dry bearings. Over time, the ball or roller bearings in both units can get dried of lubricant. The only solutions are to lube them before they are damaged significantly {beyond use} or replace them. If this is not an electric PTO clutch, then it is likely the linkage that operates the PTO clutch is in need of adjustment and/or lubrication. Most use an idler pulley on a V-belt as the 'clutching' mechanism. If the linkage is binding, or the idler pulley out of adjustment, it won't work well.
Oct 16, 2013 | Husqvarna 967 00 98-02 - RZ4623 46" 23HP...
On my snapper, diode in wiring harness burnt up and blew the PTO fuse. Any thoughts on cause. The diode is in the wiring going to the electric PTO Clutch. Thanks.
The diode is there to prevent voltage spikes in the wiring harness from when the clutch is engaged.. If it is burnt up, it will have to be replaced. The cause could be a bad clutch.
Aug 21, 2013 | Toro 52" 27hp Z Master Zero Turn Lawn...
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Pto does not engage
snapper electric clutch not worjing has power to switch
Jun 22, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
Engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
PTO problems.
If it is Electric Clutch, could be a loose wire to clutch or clutch electrical winding could be bad.
Mar 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
