Question about Whirlpool Ovens
Gas oven whirlpool gw395lepboo,Oven does not work. migration board (keypad)the only thing functional is the timer and clock display.Which schould I replace?migration board or control panel where migration board plugs into?Thanks
  • harley1 Jun 06, 2010
    Yes thankyou for your help.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You are right it is the electronic control that you be replaced, please click on this link for the parts. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Tip
Related: F2 E6 on Whirlpool RBD305PDS14 double oven - blank display
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Oct 21, 2007 | Whirlpool RBS245PDS Electric Single Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
I have an accubake system electric oven and stove. When I tried to set the temperature on the oven the degree number kept rising to 500 degree on its own. Now it is displaying E0 F2 on the screen. Whats...
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Aug 09, 2010 | Whirlpool RBS275PD Electric Single Oven
Whirlpool oven RBS245PDB2 - Was getting the E3 F2 code and just replaced the control panel. Am now getting a new error code - E0 F2. Any thoughts?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$!$
Nov 14, 2009 | Whirlpool RBS245PDS Electric Single Oven
My oven is giving me an error of E6 F2, what does that mean
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | Whirlpool Ovens
E6, f2
You have a stuck or shorted keypad. Try Cancel/Off and hold for 10 seconds. Then push every key several times to unstick. If that does not work unplug range and remove the access panel, disconnect the wire connections, then replace them. If all these steps fail replace the control. good luck
Jun 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
WHIRLPOOL GY396LXPB00 MIGRATION CONTROL PROBLEM
press and hold at the same time child lock ( 2nd button in the row of buttons under the clock. and cancel ( bottom button far right ) hold until lock light blinks (10 -25 sec) hope it helps
Jun 11, 2008 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Ovens Logo
43 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
