Question about Cycling
My speed registers faster than I am actually going
    Brigadier General:
  • 8,546 Answers
Perhaps you have it calibrated in km instead of mph, or your wheel size is smaller than the setting in the computer. Refer to the instruction of the (unnamed) computer and set it/them correctly.
Posted on Jun 07, 2010
1999 SPORTSTER 1200 NOT REGISTERING CORRECT SPEED ON SPEEDOMETER
Have you changed the drive pulley and or the rear tire size if so you will need to get a speedometer & odometer mph corrector
From sporter stuff or a site off your choice
Aug 25, 2015 | Motorcycles
If I wont to go up 10mm on a 235x35x19 tyre what size do i go to
Either 245/35/19 or 245/30/19. With the 245/35 your speedometer will read slightly slower than the actual speed, 245/30 will read slightly faster than real speed.
Jan 26, 2014 | Silly Ricer, Stickers Wont Make Your Car...
1977 harley sportster mechanical speedometer registering wrong speed
Hi Catherine, you either have the wrong speedo drive or someone has chainged the countershaft sproket to more/less teeth. Check with your local parts department for options. Good luck
Jul 30, 2012 | Harley Davidson XLH Sportster 883 Hugger...
1977 harley sportster speedometer registering wrong speed
Hi Anonymous, check with your local parts department for options. Good luck
Speedometer not registering correct speed.
Has to be calibrated on a rolling road with the correct software ,or you have the wrong size tyres fitted ,they are low profiles making the wheels go round faster in relation to the speedo calibration
Apr 28, 2012 | 2006 Toyota Corolla 1.8
What would cause my 2004 chevy silverado 1500 to register a faster speed than actually being traveled.
COULD HAVE WRONG TIRE SIZE ON THE REAR,THE SPEED SENSOR COULD GONE BAD ( LOC. AT TRANS WHERE CABLE CONNECTS INTO)
Aug 16, 2011 | 2004 Chevrolet Silverado 1500 Crew Cab
Speedometer does not work correctly all the time. Cold weather seems to make it go hay wire. Never stays stuck when the engine is off but registers 15 to 50 mph faster than actual speed
check and see if the wire on back off speedomter is loose and check your vehicle speed sensor see if working or broke and you also have wheel speed sensors that could be malfunctioning
Sep 24, 2010 | 2005 Buick Rendezvous
Speed display inaccurate
Yes and no, Yes if you know enough to go into the operating system and recalculate the the timing of it and no if you don't. Also remember that it could be your speedometer that is out as well. They are allowed a variance of +- 5mph. Hope this helps
Jun 11, 2010 | Garmin nuvi 255W GPS Receiver
Speedometer appears to register 15 miles less than actual speed
If you have replaced your stock size tires with oversize aftermarket tires and wheels (17 inch stock wheels to 22 inch wheels, etc) you need to have the computer reflashed to compensate for the larger tire size. Larger tires turn slower to maintain the same groundspeed, giving a false speed reading.
Apr 10, 2009 | 2005 Dodge Magnum
Occasional reboots
i too have found this problem with the 2 wire 2700 and found that if the router tries to alter the connection speed and finds it cannot connect at the faster speeds it has to reset itself to revert back to a slower connection speed, so keep an eye on your connection speed which can be found in the routers settings on the initial page and check if the speed registered is faster than that of which your line can carry, if so then you need to contact your isp.
Aug 31, 2007 | 2wire 2700HG-B Router (2700HGB)
Cycling Logo
102 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
