FixYa.com
Tags:
Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Lost object down vent in Jenn air S125 Stove/oven...
posted by Bettea on Apr 10, 2008
I have a 1972 Jenn Air Electric 2 burner/ 1 grill range Model S125. There is a ventilation "slot" on the top sitting between the burner unit and the grill Unit. I was cleaning it out and accidentally dropped my paring knife, then my fingers knocked it under the grill unit and it fell down the vent space on the side of the oven (left side of Oven)! I tried a magnet on a string, to no avail... How do I get the knife out of there? Can I go underneath to the power unit (also left side) which appears to be directly under the oven wall vent space? Since it sits right underneath it doesn't appear there is a place for the knife to be. The vent hose is on the right side, if I cut the cable ties and detach hose is there a way to reach past the power unit to the left side of the oven? HELP! I'm afraid to use my oven for fear the knife handle will burn and smell!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Kitchen Ranges problems?
Jenn-Air SVE47100 Slide-In Electric Kitchen...
downdraft
Hello, I have had my Jennair... Answer This...
F1 reading
Used self clean, after finished... Answer This...
Jenn Air Electric Range...
The touchpad is not doing... Answer This...
SVE47100B Jenn-Air Slide-In...
I'm trying to find the specs... Answer This...
hose size and type
I recently purchased e33658... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
