Question about Dometic Rooftop RV Air Conditioner
Air Conditioner trips the 110v breaker, only when the outside temp is above 90 degrees. Unit has been checked several time and the circuit board has been replaced, but has fixed the problem of tripping the breaker. Breaker has also been replaced.
    Novelist:
    Champion:
  • 246 Answers
'Breakers' - are tripped because they are exceeding their amp limits.
The 'hotter' it gets outside - the 'harder' your AC has to work - and under normal circumstances this is not a problem - but when you have a fan motor or a compressor that is starting to 'break-down' (electrically) - often the AC's amp draw will exceed the limits of the breaker - thus 'tripping' the breaker.
I would suspect either the fan motor or the compressor is causing your breaker problem.
Eventually - the component (either the fan mtr or compressor) that is 'going bad' will go out completely and your breaker will 'trip' and not stay on when you try to reset it.
At this point you will need a Service Tech to determine which one is bad.
There is a possibility that your condenser coil (the one that blows hot air) is 'dirty' which will also cause a problem similar to the one you have - but it is less likely.
Also - if you've had the AC 're-charged' lately - it's possible you are in a 'over-charged' condition - but again, this is not very likely.
hope this helps.
Posted on Jun 12, 2010
  • Lorraine Woodring Apr 17, 2014
    maybe. ours is a Winnebago basement a/c
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
I've just moved into a home with an existing Armstrong Concept 10 A/C unit that's at least 15 years old. When I left for a 2-week vacation, the unit was working great. I set the thermostat to 77 to save...
Hello 93 The compressor caused the breaker to trip.A weak capasitor or burnt wire is a common cause.It sounds like the compressor is NOT on even though the fan is.It may need a new wire or maybe a HARD START kit to help restore operation.Call for help.HS kits are not expensive.NO damage results from leaving it on, the problem would have happened anyway even if you went on vacation or not.The curcit breaker stopped it.Its worth fixing.
Aug 30, 2010 | Heating & Cooling
My amana ac unit over heats the circuit breaker and trips it off after running for about 15 minutes. It will not blow the fuses on the outside disconnect next to the unit outside.
What you described 'shouldn't' be happening - "if" the outside fuses and the inside breaker are sized correctly for your air conditioner.
I would make sure that the fuses in your outside disconnect were the proper size (for your AC), and that the inside breaker was of suffienct size to handle the air conditioner, and whatever else might be on the circuit.
Note: You would never want the 'outside fuse size' to be bigger than the inside breaker.
For example: 50 amp fuses in the outside disconnect and a 40 amp inside breaker is a no-no.
Often, for whatever reasons - someone will put larger fuses in the outside disconnect than what is called for.
When this happens the inside breaker is the only safety on the AC.
The problem is - for whatever reason - your inside breaker should not be tripping off.
It's likely that the AC may be on a inside breaker "that also has other things i.e. dryer, electric range or Refrigerator," and therefore any of these components 'including' the air conditioner could be causing the inside breaker to 'trip.'
One way to check this would be to 'un-plug' whatever else you had on the inside breaker - and then run your air conditioner and see if the breaker trips. Let's say you have the refrigerator and the air conditioner on the same inside breaker. You suspect the refrigerator is causing the inside breaker to trip - so you unplug it - and then turn on the air conditioner. "Now" it does not trip the inside breaker and assuming you have the proper fuses in the outside disconnect - you could safely say the air conditioner is ok - but - the refrigerator might be on the blink.
It's also possible that you just have too much on the inside breaker and you need to plug the refrigerator in to another outlet.
Still, if it was me - I think I would really think 'hard' about calling a Service Tech out - and let him/her diagnose the problem.
Hope this helps.
Jun 12, 2010 | Heating & Cooling
Rooftop RV Air Conditioner: temp outside 90 or above. compressor kicks off ....
It sounds like maybe an overload for the compressor is tripping and resetting once the compressor cools. Possibly due to a low charge.
May 03, 2010 | Heating & Cooling
Circuit breaker overheating on rooftop ac after
Possible overcharge or bad breaker. You need to check the amp draw for the unit. If you draw under full load amps and trips breaker breaker is bad.Rus
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
42 degrees outside and air conditioner is blowing hot air!!
turn the unit off at the main circuit breaker or isolating switch, to reset the unit it has tripped out on its high pressure safety. to stop this problem happening on 42 plus days hose down outdoor coil with water
Jan 29, 2009 | Heating & Cooling
579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Sep 16, 2008 | Dometic Rooftop RV Air Conditioner
RV ROOF TOP AIR CONDITIONER TRIPS BREAKER
Possible low voltage condition would cause that kind of a problem. To small a cord without the ability to carry and maintain the voltage would cause a voltage drop. I would test the voltage supply and make sure it is within 10% of that required for your A/C to operate properly.
Jun 15, 2008 | Heating & Cooling
Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Nov 20, 2007 | Ruud Central System Air Conditioner
Carrier air conditioner
Sounds like you either blew a transformer, have a bad circuit breaker or blew the main fuse in the outside disconnect. If the indoor unit is still blowing air (no matter what temperature) start looking at the power supply to the outdoor unit. From the circuit breaker, the power will go to a small box located within a few feet from the outside unit. This box will have either a lever on the side or you will be able to open the box and pull out the fuses. From this box the power goes to the condensor. The first thing you should do is to turn off the breaker to the outside unit. Flip it back on and if you have a call for cooling, after about 3 minutes the outdoor unit should start. If it does not, shut off power again to the unit by switching off the breaker, go outside and pull out the fuses in the disconnect box. Using a multi meter, check for continuity thru the fuses. If you have continuity, call your technician. If one or both fuses show no sign of continuity, replace the fuse(s). Make sure that the thermostat is working and sending a signal to the indoor air handler. You may be able to check this by turning the fan switch to "Fan" and see if the blower turns on. You may just have a bad thermostst. Caution should be used anytime you are near electrical components. If you do not have the skill-set required to test electrical equipment, leave it to a proffessional.
Sep 03, 2007 | Carrier 38CKC036 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
506 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
