Question about Brother HL-2170W Mono Laser Printer
Failed to associate - Brother HL-2170W Mono Laser Printer
    Problem Solver:
  • 5 Answers
This instruction is to setup Brother Laser printer 2170W in windows 7
Turn off Windows Firewall
To reset the printer:
Turn off the printer.
Press and hold the Go Button in front, at the same time turn on the printer from the right side. You will see three lights(Error, Drum, Toner) turn on. Release the Go button. The light is not blue and is off.
Now, Press the Go button 7 times. Wait for some seconds.
The three lights will turn on and off by themselves. The printer warms up and then stops.
Connect the ethernet cable to the wireless router and the printer
in the browser type:
http://192.168.1.1
It shows the device connected and its ip address.
Close the browser and open new browser
on your internet browser type in http://(ip address that you see as device)
click on "Network configuration"
user: admin
Password: access
click on "configure interface". Change it to "Auto Switching" Click OK
You are back in "Network configuration"
click on Configure wireless
Make sure it is "Infrastructure" and the "channel" is correct.
Also "Authentization Method" should be "open system"
Choose your encryption method
type in your password in "hexadecimal format" and click "submit".
If your password is ascii change it to hexadecimal with an online converter
Follow the instructions.
Wait until it prints the papers.
When it tells you to remove the ethernet cable, Do not remove.
Wait until printing is done. Turn off the printer and remove the cable. Turn on printer.
Now Print the printer status:
click on the Go button once to wake up the printer.
Now click on the Go button 3 times. Wait! it will print 4 pages.
Look at the last page
you will see the IP address of the printer.
go to your browser and type in http://( new ip address that you see on last page)
The last step is again in the "configure wireless" to "configure TCP/IP"
choose something like 192.168.1.198 the last 3 digits should be a high number. Close browser.
Now put in the CD and install the wireless Driver only. All Done!
Turn ON Windows Firewall
Posted on Jun 25, 2010
  • Bob Marks Feb 22, 2012
    Thank you. This would have worked immediately except my wireless access point wouldn't drop the ethernet IP address assigned to the printer so the wireless connection would fail. I had to log into my access point and force the old connection to be removed.
    Then powering up the printer connected immediately.
My 1999 grand Am tick or knocking when engine is warm
A "ticking" would typically be associated with the valve train, possibly a failed or poorly adjusted lifter.
A "knock" is commonly associated with connecting rod bearings at the crankshaft.
Using a mechanics stethescope and listening to the engine while it is running at an idle will assist in identifying the problem.
Jan 29, 2016 | Cars & Trucks
Tip
Component failures on Maytag Neptune Font Load Washers such as the pressure...
Component failures on Maytag Neptune Font Load Washers such as the pressure switch, wax motor, hot and cold water valve solenoids, timer motor, 24 VDC circuit, and the overall electrical buffer circuit have significant effect on the machine control board. Failed resistors on the control board can be used to determine failed washer components. Resistor R9 is associated with the pressure, R11 is for the wax motor, R51 for the hot water valve solenoid, R52 for the timer motor, R53 for the cold water valve solenoid, R143 for the 24 VDC circuit, and R162 for the overall electrical buffer circuit. The TRIAC Q6 is also associated with the wax motor while TRIACS Q3, Q9, and Q17 are for the timer motor, cold water valve solenoid, and hot water valve solenoid respectively. These TRIACS must also be replaced should the corresponding resistors have failed or burned out.
on May 17, 2010 | Electrical Supplies
Microwave was working fine then there was a loud pop now there is no heat everything else works fine lights vent and display
There was a component failure in the magnetron circuit. The magnetron is the device which produces the microwaves that heat the food. There are extremely high (and dangerous) voltages associated with this part of your oven. As a result, components often fail and make noise because these components can burst rather violently. You should take it to a competent service tech. The components associated with the magnetron can often be replaced when they fail and it is not always expensive to have repaired.
Jan 02, 2016 | GE Profile Spacemaker Over-the-Range...
I recently purchased a new phone and failed to logout of my facebook account before the service switched phones both of my emails and my phone number are associated with that account please help me!!
Can you please provide following details :
1. Phone make and model
2. Phone Operating System (ios, android,etc)
If its android, you can have control on the same by login to your associated gmail account.
else, Service operator can help !
Dec 09, 2015 | Facebook Computers & Internet
Wireless link status failed to associate
Try running the Brother Network Diagnostic Tool....search it on www.brother.com.....
Or you may follow the link I've provided below to Dropbox.... https://dl.dropboxusercontent.com/u/98190725/Brother%20Network%20Diagnostic%20Tool.exe
Mar 19, 2014 | Brother HL 2270DW Laser Printer
Magic focus does not work. RGB projections do not line up.
That symptom is usually caused when the convergence ICs and associated resistors fail. You can get convergence repair kits for the various Hitachi models from www.tvrepairworld.com the kids contains both ICs and the associated resistors plus the CD with repair instructions.
Jan 07, 2011 | Hitachi Televison & Video
I had some a problem with my password and after several failed attempts I was led to create a brand new FB account. I have over 1,600 FB friends. How do I recover my current account? I don't want a new FB...
go to login screen, type in the e-mail that is associated with your account, then underneath where you would type in your password. Click on that and follow facebooks instuctions. They will e-mail your password to the e-mail account that is associated with the account
Dec 15, 2010 | Facebook Social Network
Visio file association
- in windows explorer right click over the file and choose Open with... and then browse for and choose the viewer program
Apr 03, 2009 | Visio Technical 4.5 Full Version for PC
Whirlpool Duet Dryer GEW9250P (electric)
Here is a list of possible causes. NONE OF THE LEDS LIGHT... Check to make sure that ribbon connectors P3 and P4 are inserted all the way into the machine control electronics board. (To access the machine control, pull the dryer away from the wall and remove the three screws from the top panel on the back. Slide the top panel rearward about 1/2" and lift. The machine control is on the left hand side. P3 and P4 are the "ribbon" connectors going into the board.) A PARTICULAR GROUP OF LEDS DOES NOT LIGHT... A group or combination of LEDs share a common electronic connection. If this connection is open, all of the LEDs in the group will be disabled. If this occurs, replace the entire console electronics and housing. ONE LED DOES NOT LIGHT... Press the button associated with the LED several times. If the LED does not light, the LED has failed. Replace the entire console electronics and housing. NO BEEP SOUNDS... If the associated LEDs do light up, the beeper circuit may have failed on the machine control electronics board. NO DRYER FUNCTION IS ACTIVATED WHEN A PARTICULAR PUSHBUTTON IS PRESSED... If the associated LEDs do light up, the machine control electronics board may have failed. AN E3 ERROR CODE IS DISPLAYED... An E3 error code means that there is a user interface or a software mismatch. It can also mean that a component on the console electronics,or the machine control electronics board has failed. Hope this little tutorial gets you where you need to go. Let us know how it turns out, will ya?
Sep 13, 2007 | Whirlpool GEW9250P Electric Dryer
Brother HL-2170W Mono Laser Printer Logo
783 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
