Question about Victor 1280-5 Calculator
I have a 1280-4 and need the wire part that holds paper
I have a 1280-4 and need the wire part that holds the paper.
I have hp 1280 A3 Inkjet printer . When I give print it pick up paper and out the blank paper without printing . a4 printing is ok. But A3 Is majour problem
May 20, 2010 | HP DeskJet 1280 InkJet Printer
I have problem printing A3 size paper in HP DJ1280
dear use hp 1220c driver instead of 1280
the problem will be sorted-out
Mar 07, 2009 | HP DeskJet 1280 InkJet Printer
Hp deskjet 1280 unknown a3 paper
Uninstall the HP 1280 driver and install HP 1220 driver. it will print on A3 size.
Ajay
Aug 29, 2008 | HP DeskJet 1280 InkJet Printer
Print
hmmm..ok..power down completely..
unhook from computer
press button on power panel down..hold it for ten seconds, while plugging in power cable again..
system should go through start up sequence
then try a test page..
if not , time for factory service.
Aug 06, 2008 | HP DeskJet 1280 InkJet Printer
My 1280 cant print on card
perhaps this needs to be sent in from rear feed tray? usually higher stock papers won't bend as readily.
Jul 22, 2008 | HP DeskJet 1280 InkJet Printer
Setting custom paper size for hp 1280 in win vista
we loss the CD hp deskjet 1280 Serial No.CN65P8ZOHH want printer drivers
Apr 14, 2008 | HP DeskJet 1280 InkJet Printer
My hp deskjet 1280 printer is not coming on
well..sometimes when a paper jam occurs, it shuts the whole system down..
you may wish to remove the s/w for that printer through control panel
go here for updates drivers
re install the s/w
run test page, calibrate and clean cycles.
Mar 27, 2008 | HP DeskJet 1280 InkJet Printer
Victor 1280-5 Calculator Logo
44 people viewed this question
Top Victor Office Equipment & Supplies Experts
k24674
David Burbee
David Burbee
Andrew Taylor
Andrew Taylor
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
