Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Computer does not boot up when I try to turn it on.
    Genius:
  • 1,121 Answers
Any error codes?
Posted on Jun 06, 2010
I get the following error message: Check cable connection! PXE-M0F: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key
You computer is trying to boot from somewhere other than your hard drive.
Turn the computer off and when you turn it on, watch the screen for which key it says to hit to Change the Boot Order or Boot Sequence. Hit that key when you see the message or it will not work and you will have to reboot and try it again. Select the Hard Drive as your bood device and let it boot up. This is a temporary change only good for this boot cycle. You need to make a permanent change to the boot order.
To make a permanent change to the boot order or sequence, turn the computer off and watch the screen for which key it says to hit to get into the BIOS or System Setup. Hit that key when you see the message or you will have to restart and try again. Once you get into the BIOS or System Setup tab over to change the boot order or boot sequence. Normally the best sequence is to have the DvD/CD drive 1st and the Hard Drive 2nd. Just make sure when you boot the computer that you don't have a music cd or movie dvd in the drive or you will get an error message if it tries to boot from it. You want this sequence just incase you have problems with your hard drive, then you can put a repair disc or system disc in the dvd/cd drive and it will boot from it so you can try to fix the problem.
May 23, 2012 | Acer Aspire One D260 Netbook
Computor wont boot At all
try to boot your computer to safemode,restart computer then keep on tapping F8 while turning on, if nothing happens,try to insert the recovery disc that came with the computer and boot from it,
Jan 14, 2011 | Acer AOpen MX 3ZA (91.88110.101)...
Does not boot up just blank screen and then can not turn off
if it is not ur whole computer not turning on,it is ur o.s.,probly corruptedd,if it is ur computer that wont turn on,try replacing the motherboard.
Jul 16, 2010 | Acer Aspire One PC Notebook
I have problem with vga it doesn't display and it comes lines on the screen and the laptop doesn't boot too
I'm no computer expert but have done a few of vga and no boot problems. Try your vga on another computer to confirm if vga is working. If the vga works on another computer, then you can concentrate on your computer booting.
Try turning on your computer on safe mode..most computers boots on safe mode when you turn the computer on and continuously press f8, normal start up will happen but it will be in safe mode, but notice display will be a little different(bigger) ..try and restore your computer settings on a later date by doing a system restoration. Or if you know any software recently installed that might caused your computer not to boot, you can uninstall it when in safe mode...try these and see if it works.
cheers
May 21, 2010 | HP Hewlett Packard Dell XPS M1330 Business...
Unable to install XP OS to MSI lap top
Insert your installer to the lap top then try to change the boot up priority by entering the bios. Try to press del key while your lap top boot. If these deosn't wok try F1 or F2 thesame process. If you have enter the BIOS, look for the boot priority which includes the First Boot, 2nd Boot and 3rd boot. Change the 1st boot to CDROM and the 2nd boot to hardisk. Then save the changes by pressing F10. your PC will reboot and it will direct you to the OS installation.
Mar 29, 2010 | Computers & Internet
Laptop not working
try to boot the computer in safemode with networking .
first shut down the computer and then while u turn on the computer start pressing F8 on the computer for 12 times and it will give you an option for advanced boot option from the list select safe mode with networking and then try to boot the computer ,,,,,once u log on to safe mode then go to run and in run type in msconfig ,,,in system configuration box select services and disable unwanted services and then restart the computer on normal boot and then the system will work fine ,,,,,,
Jul 21, 2009 | HP 413670-001 - HP Compaq nc6320, nx6310,...
Des appplication?
Hi
Try booting up the computer in safe mode and then check for the startup items, if you see any program in the startup list try to remove it, close all the applications and then shut down and reboot your computer. This will definetly remove the application thats either not installed properly or thats trying to create a problem in booting up your computer.
Jun 22, 2009 | Microsoft Windows Vista Ultimate Edition
Gateway MX6927 Windows Xp won't boot
put your xp disk in the optical drive.Turn off computer. Turn computer back on as soon as you turn it on start tapping f 12 constantly.it should go the boot menu giving you a choice of booting from cd or hard drive choose boot from cd.Be sure you choose repair rather than new installation or you could loose all your information stored on the hard drive,I personally would try safe mode first you can get to safe mode by tapping f 6 when you first turn on your computer.
May 04, 2009 | Gateway MX6927 Notebook
Dell dimesion 4600 won't boot up
u try to just hold in power button shut down all way for min then back on
Feb 09, 2008 | Dell Dimension 4600 PC Desktop
Trying to downgrade to Xp
Sounds like you need to boot from the disk.Put the windows XP disk in the cd rom turn the computer off then turn it back on.The computer should see the disk and boot from it.Follow the prompts.You cannot downgrade if you are trying to run the installer after you computer has already booted,but you can load the operating system if the computer BOOTS from the XP disk.
Nov 15, 2007 | HP Compaq nx6310 Notebook
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
252 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
