Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fault 130 Cold water valve cycling on and off rapidly. On spin, pump cycles on and off rapidly.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting Now error code 130 means you have a Single Rotor Position Sensor Error.That means the Rotor Sensor which is attached to your motor is faulty or the wires to it are broken.The other fault it could be is the motor controller.The only way to test the Rotor Sensor is with an RPS tester.I can help you test the continuity of the wires that go to the Rotor Sensor if you have or can borrow an electrical test meter.If i had to guess which part is faulty, It would be the Rotor sensor.Hope this helps and please reply for further help.
Posted on Jun 07, 2010
My nec nwtl456 washing machine wont empty all water when spin complete anoying is it the pump or?
Can you hear the pump motor running when you first turn the program on, or during the spin cycle? a sort of glug glug noise when the drum is NOT turning. If you can, but the water is not draining, you have a blockage somewhere. If no glug glug then the pump is seized with a coin or pin etc and must be removed and freed or replaced.
Check any filters fitted first; remove and clean them. Lower the grey drain hose onto the floor - does water run out? if not, blockage maye be in sump hose or pump chamber (sock, etc)
If it does run out, blockage will be in connection to sink / waste pipe on your domestic plumbing.
Feb 03, 2018 | Washing Machines
Clothes are wet after spin cycle
U need a technician for that... there is a problem with the "flow valve" sorry can't help u out much with that... but maybe u can visit this site and hit the like button... www.facebook.com/muktidayasewa
Jan 13, 2014 | Amana 3.2 cu. ft. Top-Load Washer
MACHINE WITH AGGITATE BUT WILL NOT SPIN DURING SPIN CYCLE AT THE END. CLOTHES ARE DRIPPING WET
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Inthis case as the final spin is not working the voltage to the motor at the time of the cycle must be checked to confirm the fault of the main program controller . Also the drainpump must work after the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin. If the drain pump is clogged and not working there will be residual water and so SPIN MIGHT NOT WORK.
cleaning drain pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 21, 2011 | Washing Machines
Washing machine sticking in middle of rinse and spin part of cycle
If your machine is stopping at the rise cycle, then you have a faulty cold water inlet valve/solenoid.
To verify this, turn off your hot water tap and only leave the cold water on. Put your machine on a cold water cycle. If the machine does not fill up, it means the valve/solenoide needs to be replaced.
Also note if you had water left in the tank prior to rise cycle commencing, then the drain pump is blocked.
Ash
Sep 11, 2011 | Hotpoint Washing Machines
Hoover nextra washer was showing fault code 3. on inspection i found a ten pence piece in the in hard plastic pipe of the pump. removed blockage and set it to cycle. machine was showing fault code 1. i...
Hoover Nextra fault code 1 actually decodes as 'door interlock/door switch' (???!!)
Fault code 2 states' fill time-out or solenoid valve etc'
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 19, 2011 | Hoover Washing Machines
Cycle does not advance?
it sounds to me like its a water pump problem i think you will find your water pump is not working. if the washer cant drain all its water it will not advance further than that as the machine must detect that all the water has been pumped out before it will start to spin. thus protecting the agitator from snapping.
Jul 02, 2010 | GE WBSR3140DW Top Load Washer
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
I have a Whirlpool Ultimate Care II, top loading washer. Upon intial start up the machine agitates. During the spin cycle, the cold water remains ON, throughout the cycle. This is leaving the clothes wet...
The timer is at fault.
During the spin cycle the timer should send intermittent power to the water valve. This activates cold to help rinse soap residue from the laundry.
If cold is continuous it means the timer is not breaking correctly.
Feb 14, 2010 | Whirlpool Washing Machines
Spin cycle wont work
First : The machine will not spin with water in it. So you will half to start by checking the drain pump.
The water valve is what you will first need to check the cold water.
Jan 07, 2010 | Washing Machines
Cold water pours in during final spin
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Washing Machines Logo
508 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
