Question about Kenmore 98702 Stacked Washer/Dryer
No clothes are getting stuck, but there's a rubbing and squealing noise
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sgfhwr
Posted on Sep 30, 2010
I have an 02 Dodge Ram 1500 ,2wd.Whenever I turn left,my truck makes a squealing noise,like a worn brake pad.Checked all brakes,ok.Cant figure out what or where noise is coming from
You could easily have a front wheel bearing going bad. They tend to get louder when turning. The squeal can be from the bearing itself, or possible from the brake rotor rubbing on the brake stone guard behind the rotor when turning. That rubbing won't occur unless there is excessive play in the wheel bearing or if the guard is bent.
Sep 04, 2016 | Dodge Ram 1500 Cars & Trucks
Squealing noise when drying clothe
While the drum belt could be PART of the problem, I would suspect the bearing failing and rubbing against the cabinet.
You can purchase the belt (and bearing) from www.searspartsdirect.com
Jan 18, 2012 | Samsung Dryers
Will have burn marks on clothes sometimes
Are you sure it's burnt marks or could it be from getting hung up between the drum and cabinet and rubbing due to the drum guides failing? Look at the rear and front of the drum to see if the clothes could be getting hung there. Is the dryer making any kind of squealing noise while it is running?
Nov 26, 2011 | Frigidaire FDE336RE Dryer
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
the drying twice is a venting issue:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Whirlpool LEW0050P Electric Dryer
My dryer makes a loud noise when turned on seems to be comming from the back of the drum
Hello there: Here is the only things that noise could even beginning to come from so please read the entire list i have provided below Rear drum bearingSome dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Jan 12, 2011 | GE Dryers
Our dryer was making a loud squeaking noise for a while now it is tripping the circuit breaker as soon as it is started what do you think is our problem.
The drum rides on a bearing in the rear which cause the squeal. The squeal eventually cuts into the bearing and the whole drum begins to rub against the heating element. This causes the breaker to trip.
How it works: GE clothes dryer
Jan 05, 2011 | GE Dryers
Dryer squeals as it turns, and clothes get stuck in the groove of the dryer drum...also gets very hot as its drying
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 15, 2010 | Hotpoint Dryers
My right front tire makes a squealing noise from
that sounds to me like your brake pads may be dragging or your wheel bearing is shot
Apr 24, 2010 | 2000 Ford Windstar
Noise when spinning fast
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Dec 15, 2008 | Hotpoint WMA44 Front Load Washer
Squealing noise
possible causes are:
bra wire stuck in tub and rubs against the drum and squeals when on spin.
lip seal at front of bearings squealing - this is a difficult repair
Sep 02, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Kenmore 98702 Stacked Washer/Dryer Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
