Question about Real Action Paintball Spyder MR1 Universal Sling Mount
How to fix a spyder MR1 paintball gun
My gun wont shot and co2 comes out
  • kov13 Jan 04, 2011
    Where does the co2 come out?
    Where does the co2 come out specifically?
My paintball wont stop shooting but it has nothing to do with the co2 tank help?
The sear is not catching the bolt and resetting it properly. Or, there is not enough air pressure to push the bolt back to its original position. I would take it to a gunsmith. Parts fly out of a Tippmann if you open it up.
Jun 16, 2014 | Tippmann 98 Custom Act Paintball Gun
Spyder sonix pro paint ball gun shoots but when i shoot fast the paintballs break why and how do i fix it
You can read the reviews here, it may help you figure out the issue:
http://www.pbreview.com/products/reviews/4233/
Feb 08, 2013 | Kingman Spyder Spyder Sonix Pro Vertical...
In Paintballing what is the difference between nitrogen (N2) and CO2 tanks?
CO2 tanks are composed of liquid carbon dioxide and are used for many scenario and recreation players. When the trigger is pulled, the liquid CO2 is converted to a gas, and this expansion of gas propels the paintball forward at 800-850 psi. CO2 tanks do not work as well in colder weather or for fully automatic paintball guns
Jan 17, 2013 | Sport & Outdoor - Others
This a genesis lethal threat paintball gun I just got it and I am new to paintball what size paintball do I get for my gun please get back to me as soon as possible thank you
First off do you have a hopper and an air tank or co2 tank with air or co2 in it. If no get those things and fill your tank at a local paintball field. If yes your gun takes a .68 caliber paintball. That's really any paintball that you can buy at Walmart or sports authority.
Dec 01, 2012 | Toys
I was playing today and my 98 custom just started leaking CO2 from all the cracks it froze up and ice started coming out of the barrel. what happened and how can i fix it??
your tank loosened up, the co2 freezes the rubber seals they will have to be replaced, you can order a repair kit from the website, change out all the rubber seals on the gun and your co2 tank
Feb 17, 2011 | Tippmann 98 Custom Act Paintball Gun
I attempted to put a car stock on my Tippmann 98 custom and took apart the gun but the stock didnt fit, now when i put it back together and shot it with my tank connected the gun wont stay cocked and...
Check the O rings on the big metal striker, make sure that you have the spring on the back (where the stock would have went) in the right hole on the back plate. Make sure that your velocity is set to a reasonable level.
Oct 02, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintballs popping before leaving barrel
Well, covering the holes shouldn't cause the paintballs to burst like that. I'd make sure there isn't some aberration in the barrel but that may be hard to tell. Clean it thoroughly and hold it up to a light and see if you can see anything in the reflections inside. You can try to get someone to hone the barrel just a bit to see if that helps get rid of any small aberration(s).
You can try another brand of paint. The one you're using may be a bit brittle, or just around a while and brittle.
Also, check your chrono speed. Make sure it's not cranked up so high it's busting the balls.
You might try another barrel, but would be nice to see if you can fix this one eh. I'd try some other paint first after cleaning the barrel thoroughly.
Play hard, play safe, play with honor!
8^)
May 21, 2010 | Real Action Paintball Spyder MR1 Universal...
Real Action Paintball Spyder MR1 Universal Sling Mount Logo
498 people viewed this question
Top Real Action Paintball Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you a Real Action Paintball Rock and Ice Climbing Expert? Answer questions, earn points and help others
