Question about Toys
My older t maxx goes in reverse what do i gotta do to get it to go forward
  • 8,197 Answers
To get it to shift in to forward you need to adjust the trans. You can learn how on the links below. It is hard to walk someone through it with out having the truck in front of me.
http://www.robotcombat.com/products/images/tra4910-manual.pdf
http://www.google.com/#hl=en&q=t+maxx+transmission+adjustment&aq=0p&aqi=g-p1g8&aql=&oq=t+maxx+transmission+&gs_rfai=&fp=f0010d1349b603d8
Good Luck
Posted on Jun 06, 2010
My car goes into reverse but won't go forward. What's the problem?
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
A similar type of thinking goes into diagnosing car trouble. ... response issue, but after shifting into gear the engine's RPMs will surge, but the car won't move ..... Can anyone please explain why my car cant go in reverse but can drive forward
My car will not go in reverse but will drive forward. What could ...
https://answers.yahoo.com/question/index?qid...
Dec 26, 2007 - My car will not go in reverse but will drive forward. ... I tried putting it in neutral and pushing it backwards, but something catches and it won't budge. ... Either way, it's likely that the transaxle is going to require removal and ... the hood and movethe linkage by hand, then it would shift into gear ok for awhile. Why won't my truck go forward, it only goes in reverse? ' Yahoo ...
Feb 23, 2014
My car won't go into reverse, still okay to drive a 2 hour drive ...
Jan 12, 2011
My car won't go in reverse but it will go forward with no problem ...
Feb 6, 2010
My car will drive forward, but not in reverse... Could this be a ...
Sep 11, 2007
More results from answers.yahoo.com
Dec 16, 2015 | Cars & Trucks
I got a 1990 ford tempo I was wondering why it goes in reverse but won't go forward
Is it standard or automatic, I think it must be Standard because that doesn't happen with Automatics. If you put it in low and it only goes backwards someone had it (The transmission apart) and put the slider in back wards or something like that. Perhaps the forward gears are gone so they wanted to see if reverse works. Maybe you meant when you shift into a forward gear it doesn't work but when you shift it into reverse it does work. There is a fork like gear that moves the gears in and out of high and low range and it might be broken and it is possible if you find it hasn't been ground up in the internal gears it might be welded back in place and be sure to grind off every bit of flux so the gears can work smoothly. Best thing is to go to a junk yard that still has older cars like the Tempo so you can buy the transmission.
Dec 08, 2014 | 1990 Ford Tempo
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
98 vw beetle wont go in reverse
I have a 1998 and I just confronted the same problem. It seems to take like 1 gear in reserve and like 2 gear in 1 gear. Any thoughts? I don't really it should be the transmission since it still works going forward in 2 different gears. Thanks.
May 13, 2010 | 1998 Volkswagen Beetle
It wont go in reverse it only goes forward, the steering works fine
Hi
The ESC on this truck comes with a reverse lock out. The reason is that when you're racing, race requirements are that no reverse can be used. Now you may have accidently turned this on. Go to the Traxxas web site and download the ESC manual and follow the instructions for reverse lock out.
May 13, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Transmission
Hi
You can buy the whole transmission. It's about $100.00. You can get it from Traxxas, Tower Hobbies or your local hobby shop. The truck model number will be in the form of TRA 49xx. TRA 4910 could be yours but you can get the exact part number from the on-line Traxxas parts manual for the T-Maxx. When you download this manual you'll then have the ability to replace the transmission by yourself. Good luck
May 04, 2010 | Traxxas T Maxx 3.3 Monster Truck
How to wire a forward and reverse switch
I would normally expect this to be a wsitch with three terminals on the back. Power goes into the center. Forward goes to one outside terminal and reverse goes to the other outside terminal
(A) (c) (B)
Where A is forward, B is reverse and c is the power in.
Feb 13, 2010 | NRS Salzer Position Switch S225-61049-01
T-Maxx 3.3 wont drive
Sounds like an internal gear problem with the transmission. I would remove the transmission and open it up, anything that is broken will be easy to spot. All of the parts are available at a local hobby shop or from Traxxas directly.
Jun 19, 2009 | Traxxas T Maxx 3.3 Monster Truck
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Toys Logo
24 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
