Question about Toys
Have an older tmaxx and it goes in reverse how do i get it to go forward Do i have to adjust something or buy something to make it go forward or is something in backwards
  • stankoskibry Jun 06, 2010
    what do i need to get it to go in reverse i have a three way remote
    President:
  • 1,469 Answers
Hi, answer a little bit long,would give you a link.You can use this link as a guide for repair.
traxxas.com/support/pub/Tune-1-680kb.pdf
and
traxxas.com/support/index.php?action=artikel&cat=0&id=496&lang=en&suchbegriff=.
Take care.
Posted on Jun 06, 2010
  • 1,284 Answers
Hi, you just need to buy the FOC and install it and take out the reverse servo. Just taking the reserve servo won't work because the shifting fork will move while you're driving and go into neutral....
Take care
My car goes into reverse but won't go forward. What's the problem?
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
A similar type of thinking goes into diagnosing car trouble. ... response issue, but after shifting into gear the engine's RPMs will surge, but the car won't move ..... Can anyone please explain why my car cant go in reverse but can drive forward
My car will not go in reverse but will drive forward. What could ...
https://answers.yahoo.com/question/index?qid...
Dec 26, 2007 - My car will not go in reverse but will drive forward. ... I tried putting it in neutral and pushing it backwards, but something catches and it won't budge. ... Either way, it's likely that the transaxle is going to require removal and ... the hood and movethe linkage by hand, then it would shift into gear ok for awhile. Why won't my truck go forward, it only goes in reverse? ' Yahoo ...
Feb 23, 2014
My car won't go into reverse, still okay to drive a 2 hour drive ...
Jan 12, 2011
My car won't go in reverse but it will go forward with no problem ...
Feb 6, 2010
My car will drive forward, but not in reverse... Could this be a ...
Sep 11, 2007
More results from answers.yahoo.com
Dec 16, 2015 | Cars & Trucks
I got a 1990 ford tempo I was wondering why it goes in reverse but won't go forward
Is it standard or automatic, I think it must be Standard because that doesn't happen with Automatics. If you put it in low and it only goes backwards someone had it (The transmission apart) and put the slider in back wards or something like that. Perhaps the forward gears are gone so they wanted to see if reverse works. Maybe you meant when you shift into a forward gear it doesn't work but when you shift it into reverse it does work. There is a fork like gear that moves the gears in and out of high and low range and it might be broken and it is possible if you find it hasn't been ground up in the internal gears it might be welded back in place and be sure to grind off every bit of flux so the gears can work smoothly. Best thing is to go to a junk yard that still has older cars like the Tempo so you can buy the transmission.
Dec 08, 2014 | 1990 Ford Tempo
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
95 dodge neon wont go into reverse
Reverse clutch pack problem .
Mar 11, 2017 | Cars & Trucks
I have a ys 4500 with hydro transfer I pedal operates forward and reverse it goes forward but at times will not go in to reverse. The mower was partially disassembled when I got it are there any...
Check linkage to transmission if no adjustment you will probably have to rebuild or replace that is if the belt is tight and operating correctly.
Sep 08, 2017 | Craftsman Garden
Tororider1338hxl how do I adjust the forward and reverse pedal it goes forward but not backwards verywell
Adjustment for this machine is made with the machine in the air. There is a cam nut on the right side of the transmission that can be adjusted to give more forward or reverse. Do this while in the air to make sure the machine does not creep away during adjustment.
see a local dealer like www.arcolawn.com for more tips and parts.
Mar 19, 2011 | Toro Lawn Mower With Toro Power Tools
Upgraded a tmaxx 2.5 to 3.3. Engine break was great and runs like a scolded dog. Just aftger break in, my reverese went out. I can hear something sloppy in there. Forward is good, but I can hear something...
Hi
You don't have to upgrade the tranny, but I'm sure you've broken a gear. There are a couple options for gear sets. You'll find all these at www.traxxas.com
Jul 08, 2010 | Traxxas Toys
When going forward the tines are going in reverse
I've never seen one of these so excuse my ignorance. Is it possible that the cable to change from forward to reverse is out of adjustment? Can you go to where the cable attaches to the shifting mechanism, detach it and manually try to change from reverse to forward? Hope this helps. Good luck!
Mar 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Automatic Transmission goes into all forward
check fluid if it is a dark color and stinks transmissions probably needs rebuilt sounds like low reverse or direct clutch is bad trna will still go into loe by using forward clutch if low reverse is bad shoul be having problems with 3rd or direct in forward if forward clutch is bad
Nov 11, 2009 | 2000 Ford Ranger SuperCab
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Toys Logo
125 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
