How big of an area does a farenheat F2544 heat?
  • 34 Answers
That isn't a simple answer.
Sizing of heaters is done by calculating the heat lost over the coldest month of the year which is dependent on the build specs of your home and how cold it gets where you live. This is normaly done by engineers with expensive software.
Posted on Jun 07, 2010
My farenheat fu54 heater just stopped working. Power to it is fine any suggestions on how to diagnose the problem
you said it has power, is it before or after the wire from the fuse you have checked, check the power wire that goes after the fuse. the fuse may need to replace, and if all is good and still does not work. check also the thermal cutout, This device protects the unit from overheating, it may already faulty (it may be always in off if its already faulty), here's other to look for , power supply, heating element, Power switches, thermo couple(if any), sensors..
Nov 24, 2014 | Cars & Trucks
I am interested in purchasing baseboard heaters, particularly I have been looking at the Farenheat PHH15002 baseboard heaters. I am purchasing an 1100 square foot 2 story condo with 2 bedrooms and a...
#1 you have to calculate the heatloss of your rooms,that will tell you ur wattage require. Oil filled or not,it's just as dry. As far as ur load to panel breakers, a rule of thumb is approx 3600 watts for 20 amps,using a number 12 wire. But ur wall heaterS should suffice
Apr 21, 2017 | Fahrenheat PHH15002 Oil Filled Baseboard...
Big buddy heater caught on fire
HI try mr heater wed site there has been some recalls on these heaters , it sounds like you had too much pressure going to the heater , or the gas valve was faulty, hope this helps
Feb 09, 2010 | Mr. Heater Big Buddy Heater
I installed a 1000 watt four foot long Farenheat F2544 baseboard heater in my outdoor workshop. But it's too small for the space. I calculated that I probably need 2000 watts to heat my space. But I do not...
I could find no electrical code or mechanical code that says you can do that, so I wouldn't do that.
But have you thought of or do you have the overhead space to install a hanging unit heater? They don't require much space(just make sure you install it per manufacturers specifications) and they come in much higher BTU ratings.
Nov 23, 2009 | Fahrenheat Built-In Baseboard Thermostat...
I need a manual for a farenheat F2345nwc baseboard
http://www.marleymep.com/Develop/prod_pdf/2500wiring.pdf
i think this is the same parent company
Oct 10, 2009 | Fahrenheat Electric Convector Baseboard...
Farenheat baseboard heater F2544
I just had the same problem last night. Wire the two red wires from the thermostat to the power source from the service panel. The remaining two black wires from the thermostat connect to the heater.
Oct 20, 2008 | Fahrenheat Electric Convector Baseboard...
How do I wire up a F2544 baseboard heater with 220 wire?
in a 220 setup you don't use the white wire. just your other ones. just wire nut it off
Sep 12, 2008 | Fahrenheat Electric Convector Baseboard...
How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
