Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
My dishwasher door won't close. Jenn Air
My dishwasher door won't close. It has nothing to do with the lock out feature that allows you to lock the dishwasher from use. Jenn Air JOB1090AWB. All the controls are on the top of the dishwasher door and not accessable when the door is closed. I can see the latch inside the door and have taken the door panel off to look, but I am affraid to force anything for fear I will break it.
SOURCE: oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Posted on Jan 18, 2008
reg501
  • 413 Answers
SOURCE: jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Posted on Jun 10, 2008
VtToolMan
  • 704 Answers
SOURCE: Jenn Air dishwasher door won't close
It could be as simple as the mounting tabs being too tight up against the bottom of the countertop. You might need to loosen the 2 screws that hold the dishwasher in place against the underside of the countertop, until the latch and strike plate engage.
It might be that the countertop is interferring with the latch or that the door edge doesn't have enough clearance to properly close and engage the latching tab.
If you can't get the latch to engage, it might be that it got bent slightly in the removal and reinstallation. A simple way to confirm this would be to pull the dishwasher out about 4-6" from the cabinet and see if the catch and latching tab line up and engage. If they do, then you need to make sure there is enough clearance around the cabinet edges and at the underside of the countertop. If it doesn't engage, then it is more likely that the tab (male part) needs to be adjusted slightly to allow for proper engagement. Make small adjustments (bending carefully up or down until it goes into the latch without binding.
You should be able to get this lined up with a little effort and have things working again.
Hope you found this Very Helpful and best regards!
Posted on Aug 18, 2009
Testimonial: "The advice got the door moving better, but I appears that the latch is broken and will have to be replaced."
milten1
  • 1304 Answers
SOURCE: jenn air jcd2389ges door not closing. My 5 year
it may be no hlp at all
but ive seen this a few times your problem sounds similar
check the soda milk door sometimes that gets jamed and will prevent the door from closing
Posted on Oct 08, 2009
dltatsjc
  • 54 Answers
SOURCE: jenn air ww30430p led controls are dim can't see
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Posted on Oct 12, 2009
Door won't lock
If your dishwasher door won't lock, it could be a problem with the latch adjustment or the door seal. Some latches are designed to be adjustable, and yours may be set too tightly. Look at the owner's manual for specific instructions or follow these basic steps for adjusting the latch:
1. Spray WD-40 or other lubricant onto the latch.
2. Slowly open and close the door several times, noticing whether the door hits the strike plate (the metal plate on the top of the dishwasher frame). Use a hammer to lightly tap the strike plate to move it as needed.
3. If possible, adjust the depth of your latch by unscrewing the latch assembly using a screwdriver and reseating it. Work with the adjustment until it latches correctly.
Note: If your latch is permanently fixed, have a qualified professional address the problem.
The door seal-also called a gasket-can also cause problems if you have a brand new dishwasher or door seal. The good news is that the door seal will mold to the door's shape over the first week or so. Operating your dishwasher with the highest level of heat will help this process happen more quickly. Because the material is pliable, and because heat will soften it, it will seal to the door more securely after those first few loads.
On the flip side, an old door seal can also keep your door from closing correctly. Check the seal for signs of warping or damage. If the seal needs replacing, arrange for service, or consider doing it yourself. In most models, it's a relatively easy DIY project. See Dishwasher gasket replacement for step-by-step instructions.
For more troubleshooting steps, see Dishwasher door repair. I hope this helps!
Oct 08, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
Door won't close
Check on this visual link: door lock
Jul 05, 2012 | Whirlpool Dishwashers
Jenn air dishwasher model JDB3610AWX has no power at the control board please help
Their are a couple possiblities that could be causing that;
1) the connections where the house wiring connects to the dishwasher in of the junction box has burnt, the circuit breaker will very likely be on but the bad/burnt connection wont send power to control.
2) one or both of the door switches on the latch asm. are bad,to check those use a meter set to a low ohms setting and check for ZERO ohms when the door is closed,to check those TURN OFF CIRCUIT BREAKER remove wires from switch(s) and place one meter lead on each terminal
I hope this will help you to figure out why your dishwasher won't come on,
Gene
Aug 06, 2011 | Jenn-Air Dishwashers
My Jenn Air dishwasher door won't close. It seems the lower left corner hinge has come (out of alignment), so when you lift the door to close it it stops mid-way like the door is tilted. Not sure how...
Hello sharon. do not use it until this issue is resolved. the hinge may be loose or it may even be bent. get a flash light and check this out. the problem if it is a loose screw is that it may require a special screw driver to tighten the screws again. IF it is under warranty, call for a free repair. Otherwise check it out and see if you can find exactly what the cause is and determine if you have the right screw driver to correct it. Joe
Jul 07, 2011 | Jenn-Air Dishwashers
Dish washer will not latch
Latch is locked, but the door is open, panel will not light up. Tried to close door after loading, wouldn't close, water started running, tried to figure out what was wrong, something in the way, etc, but nothing. Then water sprayed all over, started pushing buttons, and finally it quit, now latch is locked, but the door is open.
Jul 01, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
My door will not close so that I can start the dishwasher
sometimes the mounting screws will work loose and not allow the door to shut.Open the door now look where the top of the door hits and see if the two mounting screws have worked loose and hanging down re-tighten
May 16, 2010 | Jenn-Air 24 in. JDB1090A Built-in...
Jenn air oven stuck closed after attempt to activate self-cleaning
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Dishwasher will not run
here is the link for the manual etc. if you need it http://www.jennair.com/assets/product/6_920374_A.PDF page 27 appears to describe the solution to your issue and check page 28 about the control lock feature I hope this helps :)
Mar 10, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
128 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
