Question about Samsung DVD-V3500 DVD Player/VCR
VCR tape stuck in VCR
How can I retrieve a tape stuck in my Samsung VCR?
  • Samsung Master
  • 5,380 Answers
One way is to take off the cover of the unit so that you can see where the tape is hung up and help push the tape out. (One of two problems are usually involved: the cassette cover isn't closing down evenly (a high corner blocking the travel path) or a loop of the tape blocking the cover closing.)
On my VCR unit it was ~4 screws on the back that held the cover in place. (That was VCR only. There might be a few more screws in the larger unit.)
I hope this helps.
Posted on Jun 06, 2010
I can't get the cassette out of my VCR devise in my Samsung VM6105, can't get it to reject the tape
if it is visible, then it is retrievable. use a pair of needle nose pliers and firmly grip cassette and very slowly and carefully try to pull it out. first try straight out, then a little more pressure to one side, then the other side, then pull from the bottom, and then from the top. you should eventually find some "play", at which time you can pull it out. it is possible that you will lose some of the tape when you retrieve it.
it may be the cassette that is faulty, or the player may be faulty. test by inserting another cassette, the least treasured one, in case the player will try to eat that one, too.
Mar 02, 2013 | Televison & Video
A video is stuck - how should I get it out
When this happened to me I only have to lift the cover of the VCR, and push down on the tape and it popped out. If some of the magnetic tape is stuck in the machine you might need to use a flashlight to see where to detach the tape but that should work.
Sep 03, 2011 | Samsung DVD-V5500 DVD Player/VCR
Samsung v7000 DVD/VCR .....VCR ejects tape when record is pressed
Does this happen with other tapes? If so then the micro switch could be stuck in the open position, try to give it a clean with a blast of air duster first then check the contacts on the switch. If it is happening with just this specific tape the the record tab (although in place) may be "soft" try putting a piece of tape tightly across the tab & try to record.
Aug 13, 2009 | Samsung Televison & Video
Tape is stuck in VCR NV-SD230A with errror code F04
judt open the player and pick the tape out
Apr 05, 2009 | Panasonic NV-HD680 VCR
Tape stuck in VCR
With care, it is possible to retrieve the tape. VCR housings are held on only with a half-dozen screws and once those are removed, you will be able to see the transport. If the tape itself was defective (it only takes a stretch of tape with finger oils on it) then you will see it wrapped around several things with the worst of it around the drum itself.
The transport, if its control electronics has died, can be operated by hand once you have the tape free and laying loose so that you can manually eject the tape.
If you have made it that far, you will have a cassette with a long loop of tape dangling out.
On the bottom of the cassette is a hole a little larger than a pencil in diameter and you have to use something like a pencil stuck in the hole to release the brake. Once released, you can turn the takeup reel from underneath and wind the tape back into the cassette.
Unless the VCR is totally dead, I would take another cassette, one that isn't important to you, and see if that one will load while you watch the mechanism. If it loads and can be ejected afterward, then the first cassette was at fault in the jam.
DON'T touch the surface of the video head unless you clean it throughly with a soft cloth and some window cleaner afterward.
Jan 05, 2009 | RCA DRC8300N DVD Recorder/VCR
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Tape stuck, no indicators lit
check the tip in my profile
Sep 01, 2008 | Samsung SV5000W VHS VCR
How to retrieve a stuck tape in a VCR
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn it's shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Feb 20, 2008 | Emerson EWV601 S-VHS VCR
Tape stuck
If the tape is more important than the TV you could have it taken apart by a tv repair person.
Jan 11, 2008 | Emerson EWC1303 13 in. TV/VCR Combo
Samsung DVD-V3500 DVD Player/VCR Logo
139 people viewed this question
Jerry Greenberg
Jerry Greenberg
