Question about Alpine CDA-9855 CD Player
HOW TO PLUG IN AMP N SUBS - Alpine CDA-9855 CD Player
    Sergeant:
  • 356 Answers
Connect the line out (+) and (-) to your subs.
Posted on Jun 07, 2010
How can i get my speakers fixed
It may not be the subs, but the amp could have caused the subs blowing/freezing up. If an amp is clipped it will send to much voltage to the subs, thus blowing the subs. Clipping the amp is when someone sets the gains on the amp to higher than the sub can handle. Find this out before you buy new subs. If not, you may have blown subs again.
Sep 28, 2012 | Alphasonik PSW112C Alpha 100 Series 12"...
Ive got a kenwood kvt-512 n im tryin to hook an amp n subs up but dnt know where to plug my RCA jacks from the amp 2 the radio!
Your unit should have 2 plugs in the back...one for the audio and power wires to connect to your factory connections and the other plug is just RCA connections for your video, subs and front speakers. If you have a 4 channel amp and a amp for your subs, you will have to split the 4 channel amp down to 2 and run them to your front RCA connections. Subs will connect to the sub connections. If yours are not listed then you may have to track down a wiring diagram. Hope this helps.
Jun 12, 2011 | Kenwood KVT-512 Car DVD Player
I have audiobahn amp an 3 12inch subs my amp keeps kicking into protection whats my wiring opions mono amp adnot sure what ohm the subs are
Hey sound like your amp is seeing to low of indapendece. 3 subs can be hard to wire. please give mre info on the amp and the subs? dual v/c 4ohm subs are 2ohms wired pos to pos. neg to neg.
Jan 06, 2010 | AudioBahn AW1206T Car Subwoofer
How do i check if my amp is still good?
first make sure that you have power check the red thick wire, and the remote wire with a voltmeter if its ok then disconect the rca plugs now get a pair of rca wires plug one end to the amp and touch the other end if it makes noise your amp is good ( please be very carefull as it will make a loud noise on the speakers when you touch the other end if the amp is good) good luck
Dec 16, 2009 | Car Audio & Video
What is the best way to wire two alpine SWR 1222D subs to a alpine PDX 1000 1
First off excellent choice on audio equipment, i guarantee you won't be disappointed. So your subs are dual coil 2 ohms. So wire each individual sub in series. If you don't know what this means i'll explain. On each sub there are 2 sets of wire terminals. Connect a wire from the one set's - to the other set's +. Do this on both subs and you will have the coils wired in series making each sub 4ohms. Now to hook the subs together you'll need to wire them in parallel. Now since you have your coils in series, on each sub you have one + terminal and one - terminal left. So run a wire from the + terminal remaining on each sub, and run them to your amp. Splice the ends of the two wires together and plug them into the + speaker output of the amp. Connect the two negatives in the same way and plug them into the - port on the amp. You will now have your amp running at its desired 2ohms. When wiring this disconnect the fuse on your amp power wire to avoid short problems. And if you get confused at all, and aren't sure what to do, ask again don't guess, if its done wrong you could severely damage your equipment. Hope this helped, enjoy the bass...
Sep 16, 2009 | Alpine Car Audio & Video
Pyle dryver amp light protection stays on not green light stays red i have tried to disconnect everything and plug it back up but light stays red
check your subs disconnect them the try to power the amp up if it powers up the the subs have died and it could be a problem with that amp i suggest you get a better amp
Jul 09, 2009 | Pyle Dryver PLAD213 Car Audio Amplifier
I have a jvc kds580 and i wanna run a passive Bazooka EL and 4 other speakers. Can i drive the sub with the 2 RCA OUTS on the back of the unit? If not, how do i drive the sub?
RCA Outs are very low power signal connectors. They would have a hard time running a pair of headphones.
What you need is a Power Amp that the RCA's plug into and your subs Connect to.
You need an Amp (Amplifier) that powers a similar number of Watts to what your Subs Capacity is. (ie; your subs have a ratting of 100W (Watts), then you need an amplifier with 100W per channel; that's a 200W amp for a two way (Speaker) amp, or a 400W rating for an amp with 4 channels (4 Speaker connectors)
You can run a lower power amp on your subs, and use ony a portion of your speakers capacity; but if you get an amp that supplies more wattage than your speakers capacity, then you'll blow your speakers, their performance will deteriorate slowly. eventually they will not be able to generate a clear reproduction, Speakers are irrepairable.
Sorry for the long explanation.
This is something you wan't to do right, the first time.
Cheers,
Richard.
Jun 21, 2009 | JVC KD-S580 CD Player
Car Amplifiers
one of your subs is wired out a phase for your amp you must refer to proper wiring for that amp to wire two subs it will change the impedance. for more info go to :
http://www.rockfordfosgate.com/rftech/wire_calculator.asp
and follow instructions this site will show you how to properly wire two subs to your amplifier
Feb 02, 2009 | Rockford Fosgate 800.2 Car Audio Amplifier
Subs sound terrible (Ive tried so many things)
NO it won't be your battery. Sounds more like your deck.
Jan 22, 2009 | Jl Audio 12W3 Car Subwoofer
Sony xplode 1000w amp has green light puts out no power to subs
may haveto turn sub on through the stereo itself if rca cables are good.
Jan 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Alpine CDA-9855 CD Player Logo
46 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
