Question about Whirlpool GEQ9800P Electric Dryer
End of cycle signal does not work
I have a whirlpool dyer. Model GEQ9800PW2. The end of cycle signal quit working today. Can it be fixed?
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Posted on Feb 09, 2009
  • 582 Answers
SOURCE: My Whirlpool washer (model LA5578XTWO) starts washing and quits
DOES THE TIMER KEEP GOING WHEN THIS HAPPENS, IF THE TIMER STOPS IT NEEDS TO BE REPLACED. DOES THE WASHER DRAIN IF YOU TURN THE TIMER MANUALLY BY HAND IF SO THE TIMER IS WORKING TO THE END OF THE WASH CYCLE AND STOPS THE TIME IS BAD
Posted on Aug 11, 2009
  • 949 Answers
SOURCE: My dyer is model # MDE7400AYW out of the blue the
Hi Molly,
Here is a link to your owners manual (below)
A couple of things to note you may know them already but here goes. The intelli sense will not work with Time Dry. Inside your dryer are two metal rods about the size of a pencil, if they get coated with residue from like dryer sheets the sensing will not work, you can take a rag with alcohol and wipe them clean.
If all these things do not work you may have a failure of the intelli sense board.
Let me know if I can help further.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202206688.pdf
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: My dryer has heat but
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
How do I turn on bell on my dryer
From the Whirlpool user manual:
(OPTIONAL) Your dryer may have an End Of Cycle Signal. The
signal is helpful when drying items that should be removed
from the dryer as soon as it stops.
On some models, the End of Cycle Signal is fixed.
On other models, the End of Cycle signal is part of the
Start button and is selectable. Turn the PUSH TO START
button to ON or OFF. The signal will sound only if the
selector is set to On.
Jan 22, 2016 | Dryers
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
My whirlpool geq9800pw2 dryer won't work I can
the timer's internal winding's have malfunctioned and the part needs to be replaced.
Jun 16, 2012 | Dryers
Dyer will not start, timer is working but dyer does not start cycle
You either have a bad motor or start switch. You might also have a wiring problem.
May 05, 2012 | Dryers
Control locked on my Whirlpool Duet GGW9250PW0.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
(Tip Courtesy JSRock)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 22, 2009 | Whirlpool GEW9250 Electric Dryer
Help! I have a whirlpool frt load dryer it is locked (controls)
You need to press and hold the "End of Cycle Signal" button on this model to lock or unlock the control panel. The instructions should be printed directly below the button.
Jun 30, 2009 | Whirlpool GEW9250 Electric Dryer
Jan 19, 2009 | Whirlpool GGQ8831L Gas Dryer
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEQ9800P Electric Dryer Logo
208 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
