Question about Garmin GPSMAP 4212 GPS Receiver
Plotter not responding
I recntly purchased a Garmin 4212 chart plotter and I am having trouble getting to icon representing my position to move with the boat. It only stays in one place. My compass does not seem to be functioning at all either. What should I do? It iS brand new equipment. Does it matter that I am using it in the caribbean? Antigua to be exact.
    President:
  • 1,561 Answers
Check to be sure that you are at least 50 feet away from any buildings or treea that obscure your view of the sky.
Turn on the Garmin navigator.
Wait at least 5 minutes while it locates satellites.
Check the map to be sure the Garmin has determined your position correctly.
Test the Garmin's settings by having it find directions to a location near you which you know well. Make sure its suggested route is correct.
Turn it off if it gives you accurate information. If it is wrong, select "Reset Settings" from the main menu and start over.
Take care.
Posted on Jun 07, 2010
  • ameroberts Jun 07, 2010
    The sytem is determining my position when i create it. It does not respond to any movement. The compas displays a stationary north.
  • Sulaimon Jimoh Olayemi Jun 07, 2010
    Is your Garmin GPS fully charge, if yes, then i advice you power it off and restart it again, if the problem still persist, then you might need to reset it, because it is possible that it has hanged and will need to be reset.
    Take care.
Raymarine dsm300 Circuit breaker keeps tripping g when connected to chartplotter
either the cord to the chart plotter is faulty or the chart plotter itself is dead short
have an electrician do an insulation test and circuit test on the cord and plotter unit
Jan 08, 2017 | Raymarine Boating
Hi, my Garmin 3010c is 40m off true position. I hav another plotter (not Garmin) an it't on the spot. It7s not the problem with poor signal. It has signal form 6 or more satelites but it is allways...
There are too many variables that will affect the GPS to determine if the Garmin is off or the other plotter.
The only way to verify the GPS is through controlled simulation or using waypoint averaging and survey benchmarks to confirm the location.
Aug 19, 2011 | Garmin GPSMAP 3010C GPS Receiver
I want to transfer data between my 1650 wf plotter and my compute
Yes and you have to get them from a Furuno dealer as they have to be purchased from Furuno. The cost is about $200. If I can be of assistance email me: kevin@sun-me.net
May 09, 2010 | Furuno 1650wf Gps Fish Finder Combo...
Data cards for Fununo 1850w
Furuno just stopped producing these models about a year ago. They use a special chart card. You can still purchase the cards from Navionics or C-map if you need to. I will tell you from experience that you should get your internal battery changed out if you havent done so already to keep from losing your settings and waypoints. The dealer will have to save them for you though and put them back on. Furuno made a GP7000 to replace this one and it's uses SDcards and is nothing like the rest of Furuno's product line. The best replacement for this unit is the Garmin GPSMAP 700 series. You can use your old furuno transducer if you have one (with an adapter plug). This garmin unit also has a built in GPS or you can use an external one. The 700 series will be shipped in April. Check out Garmin's website or mid-shore electronics.
Aug 29, 2009 | Furuno 1850w/Nt Gps Chartplotter C Map Nt...
GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
May 31, 2009 | Garmin GPSMAP 545s GPS Receiver
Furuno 1833C/Dgps37 Plotter creeps
Try adjusting the GPS position offset in the GPS Sensor Settings Menu.
Jan 11, 2009 | Furuno 1833C/NT GPS Receiver
Need replacement G-Chart Cartridge
Hey I too have a Garmin 235S GPSMAP, I am looking for the G-Charts, Have you found any source yet ? reach me at jim.rosemary@yahoo.com
Jim
Oct 16, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Garmin chart plotter not booting up.
Hi again,
Appreciate the update. Incidentally, most batteries for this purpose are Lithium 3 volts, coin size. Often, battery removal also performs a reset if not replaced immediately.
Though my money is really on the firmware.
Cheers.
Jun 27, 2008 | Garmin eTrex GPS Receiver
Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Jul 30, 2007 | Raymarine RL70CRC GPS Receiver
Garmin GPSMAP 4212 GPS Receiver Logo
47 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
