Question about Amana ARGS7650SS Gas Kitchen Range
Amana ACF7225A Stove top ignitors are not working. They don't seem to have power.
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
  • 1314 Answers
SOURCE: GAS STOVE
yep replace the bottom ignightor take out the rackes remove the two bott screws in the oven remove the bottom plate and just keep going down
Posted on May 21, 2008
  • 10 Answers
SOURCE: AMANA STOVE
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
Posted on Aug 17, 2008
  • 18 Answers
SOURCE: Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
Posted on May 17, 2009
  • 1531 Answers
SOURCE: replacing top burner ignitor on Frigidaire
all the screws under the cap burner need to come out of all the buners inorder to get the top off
Posted on Mar 05, 2010
Stove top and broiler work Oven won't heat
the way to check this is to first see if ignitor comes on or put an amp clamp meter on it. the ignitor needs to draw 2.8 amps or more to engage the gas valve. if it doesnt lite or draw any amps at all. check voltage to bake ignitor. it will be the ignitor most likely. but the gas valve or control could be bad.
Aug 04, 2010 | Amana AGR5835QD Gas Kitchen Range
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana oven does not work.
the most likly problem is the bake ignitor is bad. this is a common part to fail in gas ovens. the bake ignitor part number for your model is 31940001, and price ranges from $45-$75. a bad clock can also cause this issue, but I would start with the ignitor. let me know if you have further questions. shane
Jun 29, 2009 | Amana ARGS7650SS Gas Kitchen Range
Blue flames on top of stove now more yellow than red
Have it checked out by a QUALIFIED gas person!! Don't screw around with gas unless you want to wake up dead due to carbon monoxide poisoning or an explosion!!!! Gas is NOT a forgiving task-master.
Apr 02, 2017 | Amana AGR5715QDS Gas Kitchen Range
Amana gas range will not heat in "bake" mode.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jan 16, 2009 | Amana AGDS902 Gas Kitchen Range
Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Jan 13, 2009 | Ovens
Oven not lighting on Amana model agds902ss
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Amana AGDS902SS Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
110 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
